If your
microwave is displaying an error code cycle the power to the microwave by either unplugging the unit, or cycling the
circuit breaker.
If the above suggestion does not work,and the error code returns, your microwave will require service.
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
