Question about JVC Car Audio & Video
Where can i buy a wire harness for my jvc kw-adv793 arsenal for the back of the radio
4 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
SOURCE: Jvc kw-adv793. Will not turn on any ideas?
I have the exact problem with mine any luck?
Posted on Dec 09, 2013
  • 27 Answers
SOURCE: 2004 Chevy avalanche I'm got a JVC kW -xs68 CD player an there is no wiring diagram on the radio and the connections cut of the wiring harness for the truck
Hello Go to Google and type the information of your Vech and you should get your answer.
Posted on Feb 21, 2017
How to install jvc kw-xs68 radio in a Pontiac 2005
But the harness and kit from auto parts or from best buy then just match colors on radio and plug harness from old radio into new harness
Sep 21, 2014 | Car Audio & Video
I just bought a new kw-AVX740 radio and i have a 01 mustang and i don't really no how to install it
first and foremost you need to buy a car audio installation kit for your car model and year. Wal mart has some, but i think you may need to drive down to your local car audio shop and buy one from them if wal mart don't have them. Remove the old/factory radio. If an aftermarket radio is already installed then you may get lucky and find the harness already installed, but depending on what kind or radio it is( ex: DIN or Double DIN), but the specs for your radio is Double DIN(fat) so you may still need to buy the installation kit. Once you have the kit, everything is color coded, just match the wires and connect, then plug the harness after you have secured the wires. For a clean professional installation look, solder your wires(60/40 solder and soldering iron needed) and seal the connection with a heat shrink tube(audio shop carries the tube as well) and your good to go. I found you the install manual, just copy and paste(make sure all wires are connected with keys off the ignition until everything is good and connected)
http://resources.jvc.com/Resources/00/01/50/LVT2173-002A.pdf
Jul 14, 2011 | JVC Car Audio & Video
How do i match the color code for my radio in my 1996 toyota avalon
You should buy a wiring harness for your vehicle. That would solve your problem because Replacement head units all have the same color coding you should always buy a wiring harness when replacing any head unit for a proper install.
May 25, 2010 | JVC Arsenal CS-AR690 Coaxial Car Speaker
WILL A JVC KW-NT1 FIT IN MY 04 CHEV. MONTE CARLO?
If the vehicle can take double-din radio, it can be mounted.
You need to buy harness adapters.
Sep 16, 2009 | JVC KW-NT1 Car GPS Receiver
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
May 27, 2008 | JVC Arsenal KD-AR3000 CD Player
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
