New install Gree 3 head 24k btu ductless mini split. Ran for 3 weeks, then got 3 red flashes on outside unit board. Compressor does not kick on anymore. Fan units inside just blow room temp air.
We got a replacement main PCB board from Gree and got the same 3 red flashes on board. Error code in manual says: 1. Incorrect Refrigerant Charge: (Although we can't add or check pressure since compressor never turns on.) 2. Metering Device Malfunction: (Not sure what a metering device is. Is this a thermostat maybe that is broken? Maybe a broken thermostat isn't telling the compressor to turn on?) 3. Compressor Malfunction: We tested the three pins on the compressor with a multi-meter and all 3 report the same continuity/resistance. GREE MULTI24HP230V1BO TWO 9k btu and ONE 12k btu Please help if you know the solution. Thank you in advance for any/all help you can send my way.
  • Heating & Co... Master
  • 1,919 Answers
It's low on refrigerant. Chances are it's on one of the flare fittings where the copper connects to the unit. You should have a one year labor warranty from the installer, should not cost you anything...3 WEEKS???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Apr 15, 2017
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
The outside unit leds have a 29 code, before it goes into shutdown. Outside is a LAU180HSV Invertor V Split System. Installed in 2012.
That code means that the compressor is drawing too much current when it is trying to start. It is highly unlikely that the main board is bad.
May 04, 2016 | LG Art Cool LA180HSV 18,200 BTU SingZone...
No power at interior unit. power everywhere else
If this is a mini split ductless there is a control wire with 3-4 wires inside (normally red, white, blue and green) that is connected from the outdoor unit to the indoor unit. This wire feeds voltage from the o.d. unit to the I.d. unit. If all connections at the o.d. unit are good, then check for voltage at these connections at the o.d. unit. If no power at these connections then a circuit board has faulted. Call a tech. and have a tech support number ready (1-800#) in case your service tech don't have it.
May 12, 2015 | Sanyo KHS0971 9,000 BTU Ductless...
Error code u5
AC current detected circuit malfunction.
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
May 24, 2014 | Gree 24,000 BTU 18 Seer Ductless Mini...
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
