Question about Dimplex Heating & Cooling
Got Dimplex CH20BR electric fire ribbons seem to be misplaced. How do I fix this. Thanks
motor1258
  • 6674 Answers
SOURCE: Dimplex Charlbury Electric Fire -
Not uncommon for those little motors to wear out. Easiest thing to do is go to connection at wiring connector to motor, and test for voltage there. If voltage is there, then I'd replace the motor.
Posted on Feb 06, 2011
  • 4736 Answers
SOURCE: how do i change the
TO REPLACE LIGHT BULBS
1. Open the steel curtains (remove glass doors if applicable).
2. Remove the log grate retaining screws and remove the log grate.
3. Pull the rear edge of the log set forward by grasping the ember bed by the sides
(handle the log set only by the ember bed and not the logs) and pulling firmly
until the rear tab pops out from under the back ledge, then lift out.
4. Examine to determine which bulbs require replacement.
5. Unscrew bulb counter clockwise.
6. Insert new bulb screwing clockwise.
7. Replace the log set by inserting the front edge, pushing the back down until the
rear tab snaps under the back ledge and the logs are resting against the mirror.
Quantity 4 clear chandelier or candelabra bulbs with an E-12 (small) socket
base, 60 watt rating. Example GE 60BC or Philips 60CTC
CAUTION DO NOT EXCEED 60 WATTS PER BULB
Posted on Feb 24, 2011
  • 4736 Answers
SOURCE: Cant get my dimplex club
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Posted on Mar 17, 2011
  • 4736 Answers
SOURCE: Where can I get replacement stones for Palermo
The model you listed is only sold in Europe. However, if you live in or near the UK, you purchase the stones from Fires and Fireplaces Direct 085-239-0034 http://www.firesandfireplacesdirect.co.uk/cat-electric-fires.php
Hope this helped you find your stones.
Posted on Apr 07, 2011
Testimonial: "Thanks for that info, I'll be contacting them later. Good stuff 5*"
  • 4736 Answers
SOURCE: replacing bulb in dimplex electric
To replace the bulbs, your will need to remove the plexiglass front, then remove the logs and set them off to side where they won't get stepped on. Then lift up the plastic simulated ember bed. You now have access to the light bulbs. The required bulbs are 60 watt small base chandelier bulbs.
Hope this helped you, Margo. Thanks for choosing FixYa.
Posted on Aug 18, 2011
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 28, 2012 | Dimplex DS4411 Electric Heater
Motor makes a humming noise I was sent a new motor but NO instructions on how to replace the motor...do you have instructions? thanks.....
The instructions on how to replace the Flicker Motor Assembly can be found starting on Page 15 in your Owner's Manual. In case you have misplaced yours, I have included a link to it, that you can download & print for future reference, should you have to replace any more parts in the future.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Dimplex DFI2309 Electric MidSize Heater
Dimplex heaters CHB20BR owners manual how to change the light bulbs?
Changing the bulbs in your model is quite different than changing the ones in a full electric fireplace. Yours requires a bit more dismantling and removal of parts. So, I have provided a link to the Owner's Manual just in case you have misplaced yours. What you need to know is on Page 14 of the manual.
For future reference, I suggest that you download and print the manual. Then keep it in a safe, accessible place.
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Bottom bulbs don't work
Sounds light the 2- 60 watt small base, chandelier bulbs need changing. To access the bulbs and change them does require some dismantling of the base of the insert.
In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Page # 5 - Maintenance - Changing Light Bulbs.
http://partner.dimplex.com/files/domain4103/7205650100r04.pdf
Hope this helps you solve the problem. Please let me know. Thanks
May 07, 2011 | Dimplex DFI2309 Electric MidSize Heater
Dimplex SHB20 Sherbourne Electric Stove -Flame Effect not working
Call Dimplex : 1-800-668-6663 ext: 358 they are kind and very helpful, they will send you arts to repair.
Jan 10, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Apr 02, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
26 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
