Hi my Dads TV plays CDs fine but won't play DVDs
snakehead
  • 1074 Answers
SOURCE: will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Posted on Apr 06, 2007
SOURCE: DVD player not playing home burn DVDs
Laser got weak. buy a new one
Posted on Nov 07, 2007
bobntina
  • 29 Answers
SOURCE: xbox 360 wont play the games but will play cds and dvds !!!!
Mocrosoft only entended the warranty on the "ring of death" issue which was hardware related to overheating.  They did not extend the warranty to any other issues.  DVD/CD emulators and the games emulators are handled by different software.
You can try a factory reset of the console...
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the “Initial Setup” option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks
This might work only with older versions of Xbox 360 dashboard.
Press the following key combination
Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
If none of this works contact Microsoft and see if the console is still under warranty.  If not they will repair it for usually 99.00
Posted on Jan 08, 2008
tech48
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
  • 39 Answers
SOURCE: OPTIARC AD 7560A plays cds, but not dvds
if you can hear the dvd trying to spin up several times without getting anything from it under "my computer":
i would suggest you replace the DVD-rw drive
please rate my solution if it was helpful.
Posted on May 30, 2009
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.
If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
Apr 05, 2012 | Jwin Televison & Video
We have two Pioneer DVD V7400s that won't play DVDs. They can, however, play CDs. Bad laser?
Hi, My guess is that the DVDs are not compatible with the DVD player. They must be windows compatible. WMA or WMV (MP4 format) or (avi) Make sure the your DVD player is indeed a DVD player and not a CD player. Good luck.
Jul 26, 2011 | Televison & Video
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Can't get Blu-Ray DVDs to play through my Acer laptop to LCD TV
The specifications of this laptop states that it has a Dual layer DVD R/W drive. This drive can only play DVDs and CDs but not BluRay discs and it can burn single and dual layer DVDs and CDs.
Jun 20, 2009 | Acer Aspire 5610-4648 Notebook
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Plays music cds but wont play DVDS
Hi ,
You should do...
1- clean to lens
2-change with new lens
3- change the spindle motor
I hope to fine it.
Dec 30, 2007 | Zenith DVP615 Portable DVD Player
DVDs won't play (but CDs will)
Did you try to clean lenses on laser head?
Sep 28, 2007 | JVC FS-S77S DVD Micro Component Stereo...
Computers & Internet Logo
David Payne
David Payne
