Question about Irons
My swann 2400 iron is making a high pitched noise every time I lift iron up whilst ironing clothes
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
Posted on Jul 24, 2008
  • 1723 Answers
SOURCE: brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Posted on Jul 02, 2009
SOURCE: how can i clean my tefal iron/ surface
tough soapy sponge
Posted on Dec 27, 2009
SOURCE: water is leaking out of the iron onto the clothes and ironing boa
Wait until the iron is fully warmed up. Keep a towel nearby for the first time you turn the iron flat, press the steam button, check for leaks-then iron your clothes.
Posted on Jan 06, 2011
My new vaporella 650 steam iron is making my clothes wet whilst ironing as it drips water constantly
Clothes are very difficult to iron when they are fully dry or over-dried in the dryer. Over-dried clothes are resistant to reshaping, which it exactly what ironing is. Removing clothes when they are still slightly damp will make ironing much easier. If you line-dry your clothes, bring them inside to iron when they are not quite dry.
Nov 12, 2017 | Irons
My iron every so often makes a high pitch noise
There are several possible answers:
1. The iron has some scale build up and the steam is escaping and clearing a path until it builds up again.
2. If you have an iron with an electronic display or any type of circuit board - we have heard components on them make noise usually no problems.
3. It is highly suggested to read through the owner's manual as this may be a simple cleaning procedure or you may be directed to contact the manufacturer.
4. If are unsure, please contact the manufacturer for further guidance - your safety is of the utmost importance.
Best wishes,
Aug 25, 2016 | Irons
Every time I iron water leaks out makes round circles on my clothes. Please help!!!
Nov 28, 2014 | Irons
How do i stop water dripping onto my clothes
ensure that your iron temprature is high enough to generate steam. if ironing delicate cloth ensure your steam option is switched off. if your iron has a filler cap or water container ensure they are fitted securely. water dripping usually when the iron is too cold to turn it to steam or you have a leak somwhere.
May 21, 2014 | Irons
I need to use the self clean on my Rowenta professional iron
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
Feb 14, 2010 | Rowenta Irons
How do I get rid of burnt starch on my Bosch Iron?
i use a wet green scarer when iron on warm
Oct 24, 2017 | Bosch TDA2445 Iron
Dripping brown-spotted water on clothes while ironing.
Your water could have high iron content, therefore empty out the old water and use Distilled water in the iron.
If you are using Distilled water already then it's a problem with the inside of the iron. Get a new iron.
Apr 22, 2009 | Rowenta Effective DX1900 Iron with Auto...
Holes clogged with plastic
I would put the un-plugged iron in to the freezer so as to get the plastic as rigid as possible and then try to extract all of the plastic from the steam holes.
As far as cleaning the irons surface.
Step1 Place about a teaspoon of salt on a paper or cotton towel and run the iron over it on the high setting gently with the steam off. This will cause the dirt to stick to the salt and will wipe away easily. Step2 Rub the iron across newspapers to remove a waxy build up on the surface. Use the high setting with the steam off. Step3 Apply ammonia to a rag and use it to wipe the surface of the iron to remove oil. Use a separate cloth that is wet with water to rinse it off. Make sure the iron is turned off. Step4 Combine equal parts vinegar and baking soda and scrub the surface of the iron with it. Use a separate clean cloth to wipe away any residue. Step5 Heat in a saucepan a cup of vinegar and sprinkle in about a teaspoon of salt. Heat the mixture until the salt is dissolved. Use this to clean the iron's surface with a clean cloth. Use a second cloth to wipe away any residue.
Good luck
Mar 22, 2009 | Tefal Ultraglide 1549 Iron
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Nov 27, 2007 | Rowenta Perfect Iron
Irons Logo
95 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
