Washing machine model sf-140jjs shows fault C3 won't start.
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Posted on Dec 19, 2010
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Washing machine sf p105jj error c3
I had this problem in my sf-p105jj...check the lid from inside on the top left there is magnet inside plastics rectangle if any thing stick in it like piece of iron remove it or try to get the magnet out and clean it up for many times.... Hope it is work with you.
Jan 08, 2014 | Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
Hitachi washing machine model SF-150GJX showing error F9. Any one knows what this means?
My washing machine hitachi SF-110LJS showing F9 ERROR
PLEASE HELP URGENT
Sep 07, 2012 | LG Washing Machines
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | AEG Washing Machines
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Jul 29, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
