Question about Refrigerators
Fridge light on but no display
Display unit is off Compressor is also off
  • 54 Answers
SOURCE: Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Posted on Feb 12, 2008
refritech08
  • 149 Answers
SOURCE: compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Posted on Apr 23, 2008
aasc
  • 1606 Answers
SOURCE: I have a whirlpool side by side fridge. This
You have a bad control board . Pull the refrig out and remove the lower back panel . On the left side are 2 screws holding a white plastic
" box" . Inside this box is the board with 2 ( ? ) group plugs plugged onto it . This board is easily replaceable and costs about $ 75.00 . If you had given your model number I would have given you the part number , so take your complete model number with you when getting the part so you get the correct board .
Posted on Jul 23, 2010
bobhifi
  • 635 Answers
SOURCE: lights in unit come on
The light in the unit indicates that you have no blown fuse and your primary power ( main power ) is OK. The GE has a digital control module which controls all the working functions of the fridge. Now if your display on the door is not working it means a failure in this section.
Are you up to dismantling the door and using a electronic multimeter for diagnostics ?? not to mention access to spare parts. Revert back for more help
Posted on May 01, 2011
bugoy31
  • 1238 Answers
SOURCE: None of the recommended solutions appear to be
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...
Thanks for using fixya....
Posted on Aug 13, 2011
Fridge was over temp, and had no volts to the compressor, so changed PCB, but still have the same fault
before go further check your compressor alone in ohms law
you may find a short circuit comment
Sep 16, 2015 | Refrigerators
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Ny aeg fridge is not cooling now showing +12 oc all lights on & display seems OK I can hera a slight "girgling noise from within the fridge
Hello,turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Thanks
May 30, 2010 | Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
FrigidLights on in freezer, off in fridge. Compreaire FSC23F7DSB8
did you clean the compressor compartment while you had it pulled out? its possible you pulled a wiring harness loose removing power from the fresh food side of the refrig and from the comp.
Jan 22, 2009 | Refrigerators
Power on but fridge/freezer not working (only lights)
Yes, boards may need replacing, but not at the expense of the door, apparantly your "engineer" would rather work on older models that may require a hammer. Best advice would be given knowing the make and model number of your unit. A professional should be able to diagnose the board processes as well as the compressor in a short amount of time. Check the defrost heater (after pwr is restored to unit) for the freezer side (placement depending upon model) for continuity (basically a heating element for the evaporator coils - which will freeze without defrost). Proper defrost will help lessen the load on the compressor. Check the overload relay on the compressor itself for failure and replacement of relay. Have the unit defrosted, svc defrost htr, thermostats/thermolinks , compressor, before checking computer board operations.
Oct 25, 2008 | Freezers
Feb 07, 2008 | Freezers
Not cooling
- Check if there power is a supply by opening the door of fridge, if there is a light then there is a supply. But no light check the circuit breaker. Or try another outlet for testing. If your fridge is digital control and there is some error display, then reset the error.
- Check the thermostat setting if set to high cool, and check the compressor at the back of the unit if running, if not there is something wrong to your control or compressor itself, if the compressor is operating and no cool at all maybe your unit is out of refrigerant, please call a qualified technician.
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
