Question about Lands Phones
Base unit not working. Is there a way to restart, only 18months old.
Lighting knocked out a base of VTech 15950. I replaced whole unit, working ok. But old handset, registered with old base shows "Out of range OR No power at base ". It doesn't response to any button.
There is a registration process you have to go through with each handset to connect the old handsets to the new base. It should explain it in the users manual for the base.
Mar 22, 2017 | Vtech Lands Phones
Unable to change handset registrations from old base to new.
Hello Linda,
See if my FixYa Answer from this previous post helps to Deregister and Register your old handsets to your new base.:
My phone says no link to base but am right beside it
Regards,
-Ellsworth
Mar 25, 2017 | Panasonic KX TG4031 Cordless Phone
Blue line
This usually happens when there is a defective CCD unit, This is the part that looks at the image and sends the signals to the cameras electronic systems. the unit has failed and will need to be replaced.
Jan 21, 2013 | Canon PowerShot SX130 IS Digital Camera
My keyboard not working?what will i do/
If you can get hold of an external keyboard, that might be a temporary solution (usb type, unless you have an older laptop with the old ps2 connection) Otherwise restart the computer (I assume mouse/pad is working,) and see if it works then. Otherwise, on restart press f8, and try last known good configuration in the choices. On laptops usually there is a cover strip at top of base unit to remove, and a sometimes screws at the base , and top of keyboard that holds the keyboard in- if you are not up to removing it to do it yourself-- If none of those work, you may have to have the keyboard replaced.
Jan 07, 2011 | Toshiba Computers & Internet
Hi I have a Panasonic VIERA TX-32LZD80 32 in. LCD TV TV which will not turn on. The standby light will flash continuously, but will stay on red if I press on the on button using the remote. My TV is...
BECAUSE THE QUESTION WAS ASKED BACK IN December 8, 2010, it is more likely that he has moved on. Anytime you have a product UNDER WARRANTY, USE IT OR LOSE IT. THINGS HAPPEN. DEVICES FAIL.
Dec 08, 2010 | Panasonic VIERA TX-32LZD80 32 in. LCD TV...
Base no longer working. Unit is plugged in.
go to your neighbour"s house and check it there.
Jul 21, 2009 | Lands Phones
My Navman N40i won't switch on
turn it off at the bootom of the unit then turn it back on via the same switch. then pug in the charger and it should turn back on. it works for me when it happens to mine.
Jan 21, 2009 | Navman NavPix N40i GPS Receiver
Base unit cuts out and resets by unpluging and pluging in.
It sounds like your handset's battery is failing on you. How old is it? If it is more than a year or 2 old, you might want to replace it.
Nov 07, 2017 | Panasonic Cordless Phone Headset Headset
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
