Question about Daewoo Refrigerators
My Daewoo refrigerator is freezing where it should be freezing(top), but not cooling where it should be cooling(bottom).
  • Brett Duxbury
    Brett Duxbury Apr 15, 2017
    Hi Oliverio Sandoval, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    is the freezer part defrosting ?
    Is there a heap of built up ice at the back of the freezer that is stopping the cold air being blown down to the fridge part?
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
  • 311 Answers
SOURCE: Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Posted on Nov 28, 2008
TheMobilian
  • 8220 Answers
SOURCE: Bottom of refrigerator will not cool...while the freezer over freeze and packed with ice
What you have is a defrost problem. Most likely the defrost heater has failed. Read more about it HERE
Posted on May 16, 2009
Greg20
  • 149 Answers
SOURCE: Freezer not freezing
sounds like your loosing freon.
Posted on Jun 11, 2009
  • 24 Answers
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Daewoo american fridge freezer not freezing and not making ice
I think it is your thermostat this controls the motor theirs a top 1 & a bottom 1 they both control the motor 1 4 freezing the other chilling because u say they are both not working it is also posable that ur f/frezer may need re charging
Sep 03, 2012 | Daewoo Refrigerators
DAEWOO FRSU20IAI FRIDGE FREEZER NOT FREEZING AT THE TOP BUT FREEZING AT THE BOTTOM AND FRIDGE IS NOT COOLING
I'V JUST HAD THE SAME PROBLEM AND IT WAS THE
EVAPORATOR FAN MOTOR . TOOK ME A WHILE TO FIND OUT BUT GOT IT SORTED . EASY FIX THOUGH .I FOUND OUT IF THE COMPRESSOR IS RUNNING THE EVAPORATOR FAN MOTOR SOULD BE RUNNING ALSO, OPEN THE FREEZER DOOR AND HOLD THE LIGHT SWITCH IN YOU SHOULD THEN SEE THE FAN SPIN . IF ITS NOT ITS BROKE. BEWEAR THOUGH AS MINE SPUN AFTER SWITCHING THE SUPPLY OFF FOR 24 HOURS BUT AS SOON AS THE FREEEZER WAS COLD IT STOPPED ALL TOGETHER AGAIN . MOTOR MUST OF BEEN BREAKING DOWN AT A CERTAIN TEMP!
Nov 03, 2011 | Daewoo Refrigerators
The refrigerator compartment will not cool the freezer is still freezing top temp 70 bottom temp -10
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Amana ABB1927DES Stainless Steel Bottom...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Bottom is freezing properly but, the top refrigerator is not getting cold
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 03, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer freezes then defrost,refrgerator is not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Daewoo Refrigerators
@15 yr old GE top freezer fridge. Top freezer
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
Item in fridge freeze at the bottom, but barely cool at the top
has the cold air circ fan stopped or jammed? this will allow the cold air to drop to the bottom and not circulate.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
43 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
