Question about Mitsubishi Televison & Video
I have a wd 60735 that will not turn on the only thing on is the timer light
  • 32 Answers
Check the bulb for any life left on it. The TV will not turn on if bulb is bad
Posted on Jul 24, 2009
How do i reset the lamp timer on my mitsubishi model wd-60735
Not going to fix that if the set even has that (which I doubt). Was the lamp a Mitsubishi or a generic cheap replacement?
when set goes off look to see if lamp is off or on, If you have to turn set back on or when its off, do the sets self check--press and hold both the menu and device buttons at same time for 5 second and release both---power light should blink a digit error code like 1,2, blinks pause and repeat that (1,2 is no error found and 3,7 is lamp issue.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
-- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
When I replace the lamp in my wd 60735 is there a timer I have to reset ?????
As soon as the set is powered up after replaceing the lamp. The set should bring up the screen that asks if you have replaced the lamp. Just select yes and that resets the lamp life.
Nov 05, 2010 | Mitsubishi WD-60735 Projection Television
I changed the bulb and tv worked fine for a day. Now the tv shutsitself down after about 5 minutes.I turned the timer off and reset the system and the problem still exists,
suspect a defective lamp....by the the way, it is called a lamp, not bulb.......second, it could be the ballast......and third it could be what's called the light engine or light box........the last thing could be the color wheel. definately suspect the color wheel if accompanied by a high pitch squeal.....
Nov 27, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
Aug 22, 2009 | Mitsubishi WD-60735 Projection Television
Televison & Video Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
