Question about Pramac Electrical Supplies
I want the manual for pramac GSW275V - Pramac Electrical Supplies
What is the name of the agent in Trinidad?
Aha, you mean the Pramac agent? There is not one in Trinidad, the nearest listed is in the Dominican Republic. See here
http://www.pramac.com/worldwide
May 04, 2016 | Pramac Electrical Supplies
Pramac any ideas why is my Pramac S12000 3 Phase Generator is only producing 26 volts. It was working fine at the full 400 yesterday. It is just over 2 years old but has only operated for about 40 hou
The first thing I would look for would be internal fuses blown. This sounds like a 460 volt 12,000 watt industrial generator and you probably should call the installing contractor for service. My 15,000 watt generator is over 30 years old and has less than 700 hours on it and those are mostly test-run hours.
Dec 13, 2014 | Pramac Electrical Supplies
How to change oil in pramac gsw 50kw towable generator?
If you have a Yanmar engine...
There is a hose that is connected to the oil pan in place of the drain plug directly under the oil filter that will have an end cap. This hose is used to drain the oil into a waste container.
Download the service manual located at the address below and follow the instructions in the manual.
http://www.martindiesel.com/Documents/New%20TNV%20DIRECT%20Service.pdf
Hope this helps.
Aug 21, 2013 | Pramac Electrical Supplies
Perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
May 24, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Electrical Supplies Logo
50 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
