Question about Vivitar 8X22 Compact Porro Classic Series Binoculars
In what order do the lens go in the left eyepiece?
I have a vivitar 8x22 PV series.In what order do the lens go in the left eyepiece, it's blurry.
  • 112 Answers
Ocular lense wich is usually smaller is the cloest to your eye, then spacer, then field lense, then lock ring gl...larry 15088331232 curves face each other
Posted on Aug 13, 2009
Vivitar 76700
Do not know where you live but humidity will fog the eyepiece. Put the scope out with the covers on for at least one hour to reach thermal equilibrium. Use the lowest power (highest number) eyepiece first.
Sep 06, 2014 | Bushnell 675x5 EQ Reflector Telescope
Cant see anything ?
I going to straight forward on this answer. This telescope is a useless piece of junk! The tripod is unstable, the .965 (obsolete size and design) eyepieces will only focus dead center. The finder is useless, too narrow a field to find anything. The high power eyepiece exceeds the maximum useful magnification (only 98x max under perfect conditions) This may be used for terrestrial viewing but worthless for astronomy.
Dec 18, 2011 | Vivitar (1607225) Telescope
I have purchased 60x/120xRefractor Telescope with tripod vivitar series 1/ we see nothing out of it at all what has happened
Take the scope outside during the day time. Remove the lens cap-- put the diagonal into the focuser at the rear of the scope. Put the eyepiece with the largest number written on it into the diagonal. DO NOT use the 2x barlow-- practice focusing on a distant object during the day time.
The moon should be your first target at night.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 31, 2011 | Vivitar Optics
Hello there, my name is Paul and I had just recently purchased the Vivitar Refractor Telescope 60X/120X with Tripod. I have assembled everything correctly, however I have tried to view the moon, but I...
This is one of the worst telescopes you could have purchased. Plastic eyepieces and a plastic focuser! We receive many complaints about not being able to focus.
Try again--- next time buy one of these which is the best value in amateur astronomy.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Nov 14, 2010 | Vivitar (1607225) Telescope
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
Does this telescope need accesories for proper function
Do you have eyepieces? At least two? The bigger the number on the eyepiece the LOWER the magnification-- something around say-- 20mm and 10mm ??
Usually their is a small "finder" scope attached to the top of the main tube to use to help you center and find distant objects. ??
and of course a tripod to hold the telescope.
Look through this web site--
http://www.agenaastro.com/
Apr 14, 2009 | Vivitar Optics
No lens
I am assuming by "lens" you mean eyepieces.
You don't need to get Vivitar brand eyepieces to get additional ones for your telescope. I'm not sure of the specifications for this particular telescope but in general they come in two barrel sizes for the eyepieces. The diameter of your eyepiece is probably 0.965" but could come in the more standard 1.25". You can measure the diameter and determine this quickly.
Once you know the diameter to shop for you can look for the focal length of the eyepiece you wish to purchase. They are rated such as 4mm, 10mm, 25mm, etc. The smaller numbers give you higher magnification. You can calculate the magnification by dividing the telescopes focal length by the eyepiece focal length. For example, let's say your telescope is has a focal length of 360mm and you have an eyepiece rated 10mm. Divide 360 by 10 and that gives you a magnification power of 36.
You can find eyepieces at many telescope dealers on the internet. Your selection will be far less if you use 0.965" eyepieces. You can purchase 0.965" to 1.25" adapters so that you can use the larger eyepieces with your telescope. However, on some telescopes the adapters will cause the new eyepiece to not come into focus.
You'll also find that eyepiece prices go all over the place. A good general purpose eyepiece is a type called the Plossl. The better eyepieces have more coatings too that allow more light to get through to your eye. You'll find these listed with terms like "fully multi-coated".
I hope this helps.
Good luck and clear skies!
-jodair
Mar 05, 2009 | Vivitar (1607225) Telescope
Need lens for vivitar telescope
You sure it did not have one or two eyepieces???
Anyway-- eyepieces come in 3 sizes--- .965, 1.25, and 2 inch sizes--- your's is either a .965 or a 1.25 measure the hole---
You can buy eyepieces at these web sites--
http://www.telescope.com/control/category/~category_id=eyepieces/~pcategory=accessories
Jan 04, 2009 | Vivitar (1607225) Telescope
Vivitar 8X22 Compact Porro Classic Series Binoculars Logo
126 people viewed this question
Top Vivitar Optics Experts
Clint Collins
Level 1 Expert
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
