Question about Lands Phones
It says I need to register my phone how do I do this?
How do I register a cs6114 phone
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
Nov 17, 2014 | Vtech 5.8GHz Analog Cordless Phone
How do I register and how do i copy one phone book to the other handsets
THE EASIEST WAY IS TO SAVE ALL YOUR OLD CONTACTS AND INFOMATION TO YOUR SIMS CARD AND PUT THAT CARD IN YOUR NEW PHONE..(OLD PHONE)...GO TO CONTACTS...SELECT CONTACT SETTINGS...SAVE TO SIMS CARD, (NEW PHONE)...SELECT SAVE TO PHONE, OR JUST CONTINUE TO USE THE SAME (OLD) SIMS CARD!
AS TO REGISTERING...YOU WILL NEED TO GO-ONLINE...IF YOU DON'T HAVE INFO ON PHONE ON HOW TO REGISTER...THAN DO A WEB SEARCH... ENTER MANUFACTURER AND MODEL NUMBER, YOU'LL FIND THE SITE TO REGISTER YOUR PHONE.
HOPE TRHIS HELPS!
Sep 03, 2011 | Cell Phones
Needs to be registered, been waiting 4 the activation screen to finish, been almost 3 days..
you have to go to and authorized t mobile retailer to register your phone or to activate it.
May 16, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Lg website to register my phone
"http://newchocolate.lge.com/au/support/registration/support-sign-in.jsp" firstly u need to register for an account for free & register for free...... Njoy......
May 01, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Phone won't register
Try this,
remove the battery from each of the handsets that will not register for about 30 seconds. Reinstall, and try to register the handsets.
I had the same problem, and this is how I got it to register.
Reply back if this worked.
Jan 23, 2009 | Uniden Cordless Phone
Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
Can't register the handset
I have the GE 28811 series and to register mine you have to unregister it first then go to your phone setup menu and select register and it tells you to hold the base page button for 5 seconds then hit your program button on the phone and it registers it.hope that helps.
Jul 04, 2008 | Uniden Cordless Phone
Restting the phone handset number
I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
Jul 28, 2007 | Panasonic KX TG1000N Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
