My machine smells have clean draw an filter what else can I do please .?
    Top Expert:
  • Washing Mach... Master
  • 50,354 Answers
Call a repair man , many times things need to be seen to FIX
Posted on Apr 15, 2017
My washing machine wont wash or spin proprly
the water is not pumping out because you have a blockage in the filter unit which is located at the bottom of your machine or possibly a weak pump. the reason that your machine smells is because the water is not discharging. check the filter first for any blockages, i.e coins, bra wires etc. if that doesn't sort it you may need a new pump
May 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have lost manual can you run something thru a load to clean machine such as vinegar or baking soda my machine smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 29, 2011 | Kenmore Front Load Washer
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Smells like old smelly socks
this might be coming from the rubber door seal clean it all the way round make sure holes at bottom are not blocked and the rubber door seal is all clean. also clean the draw so there is no power left in there and it is all clean. also a good thing to do is run it though a cleaning cycle with normal detergent at max temperature that the machine can do. hope this helps.
May 20, 2010 | Creda IWD12 Front Load Washer / Dryer
Loads of slimey grey water in filter drawer and horrible smells
First of all, you need to confirm if the leak is from the filter or the pump.
You can replace the filter seperately to the pump.
If you replace the filter, and it still leaks, then you are going to have replace the pump.
I would suggest that that you check and clean if needed the outlet pipe where the water enters the outside waste pipe.
Make sure that you do a boil wash periodically, to ensure that the drum and other internal parts are clean.
Clean the door seal and dry after each wash, it helps to leave the door slightly open
Please leave any comments that may have as regards to my suggestions.
Thankyou.
Nov 25, 2009 | Washing Machines
Is there a filter on the wmt 03 hotpoint washing machine
We have the same machine which had the same problem, there is no filter only a colection pot at the bottom of the machine. Unfortunately even cleaning this did not solve ours, in the end I had to strip the machine down, split the drum down and then flush the brown crud which had accumulated behind the steel inner drum. Ta da problem solved!. Probably not what you'd want to do if you were not confident in attempting it but it saves buying a new machine.
Sep 09, 2009 | Washing Machines
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
Sep 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Smelly drum
clean the draw out and make sure the rubber door seal is clean if that is all clean then you need to do a cleaning cycle do the hottest wash with the normal detergent now the machine should smell nice hope this helps.
Aug 15, 2009 | Zanussi FS1055W Front Load Washer
Strong meldew smell from washer
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
May 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
