Question about Vax Vacuums
My vax cordless charger has started to flash blue instead of staying on like it used to
HI I HAVE A VAX CORDLESS WHERE CAN I FIND THE SERIAL NUMBER
Look on the bottom of brush head area, on base of stem leading to brush head. Failing that contact van I have found them very helpful.
Nov 18, 2017 | Vax Vacuums
Dyson v6: It looks like it stopped charging.
If it's only 2 weeks old, you could have a defective either charging system or just a bad battery. Most places offer free replacement within 30 days of purchase. I would take it back to your place of original purchase. I hope that helps!
Mar 21, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Vacuums Logo
55 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
