Question about Refrigerators
How do you change a thermostat in APP6403 integrated freezer?
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: DIPLOMAT FREEZER MODEL NUMBER APP6403
This kind of a problem could be caused by;
The system has a leak and is not reaching the shut off temperature of the thermostat.
The compressor is worn out and not pumping gas fast enough to reach shut off temperature.
Dirty condenser not allowing the system to get rid of the heat.
Posted on Jul 31, 2008
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Sub zero 361rfd
The problem is in your description. It is the thermostat.
Make sure no loose wires .if no loose wire is found just change out the thermostat
Jun 03, 2017 | Refrigerators
REFRIGERATOR IS NOT COLD
If the freezer side is working and the refrigerator is not, its either your evaporator fan motor in the freezer side isn't running, or a defrost system problem. Open the freezer door to listen for the fan, and at the same time look to see if you have a build of ice on the back freezer wall. If you do, there is no circulation from the freezer side to cool the ref. The defrost system consist of a defrost timer, defrost thermostat and defrost heaters. The heaters rarely go out, so if you have to change the timer change the defrost thermostat as well since its a cheap part anyway. timer part number is 2188159 and the thermostat part number is 2196155.(called a bi-metal thermostat.)
Oct 31, 2010 | KitchenAid Superba KSRG25FK Side by Side...
My Hotpoint BL11 integrated fridge wont chill even with thermostat turned up full. Please help.
look for frost build up in back of freezer and if so you do have a defrost problem and the air flow is restricted causing poor cooling mm ,,
Sep 01, 2010 | Refrigerators
Freezer is fine but fridg is warm
Good day,
Sounds like the defrost system failed. Without the make.style and model number, I can only talk in general terms.
The defrost system, is made up of 3 parts. The main heater, defrost thermostat, and defrost control (which can be mechanical, electronic, or on some machines integrated into the motherboard.
Here is a great tutorial to start with.......
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 21, 2009 | Refrigerators
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
Oct 16, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
DIPLOMAT FREEZER MODEL NUMBER APP6403 MOTOR RUNNING CONTINUOUSLY NEW THERMOSTAT FITTED STILL THE SAME MOTOR KEEPS RUNNING
Jul 31, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
