Question about Samsung Washing Machines
My samsung top loader spins and stops in a second, fulls water but not complete its cycle. Model WA10B7Q1.
    Habit-Forming:
  • 94 Answers
Tere is a problem in motor of spin loader
Posted on Apr 17, 2017
Simpson washing machine
More info would be helpful (model? top loader/ front loader?)
If it fills then stops filling (ie. knows that it is full) yet does not turn, and no sounds etc, it is likely a motor control module or motor start capacitor or maybe PCB (If fully electronic). Does it spin if you manually turn the cycle to the spin point?
May 27, 2014 | Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
After any wash cycle it stops; will not eliminte water or spin
First check the drain and screen to check for clogs. Also check drain hose. check to make sure door switch and wires are not loose. Look to see how many other sensor you have in the machine. You can test any sensors and wiring for current/resistance with an ohmmeter or multi-meter.
Jun 03, 2009 | Frigidaire Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
