Question about Sony KV-T29CF1 TV
TV has audio sound and no picture
Hello, i have the TV trinitron 36XBR400 about 6 yrs old. when i turn TV on, i hear sound only with no picture (black on screen). i turn it off. it goes off and i haven't seen any problems. i turn it on again. i hear sound without pictures. Do you have any ideals what cause problem? How do you fix it? Thanks, trung no picture
  • 934 Answers
Trung,
There are many possibilities and most of them have to do with the "D" board, Sony p/n# A1346948A but testing is something generally beyond the scope of those less than technically equipped. You could order the whole board and put it in but that might be more than the simple fix you wanted or you wouldn't be here. So my best advice is to take it in to a qualified shop and have them estimate and repair it.. I see 3 or 4 of these sets in my shop a month, Sony XBR, and they're still very much worth the repair..
Bill
Posted on Nov 22, 2007
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
1999 sony trinitron color tv -no picture-no sound.
Hello c_car,
What is happening is that the Shutdown Circuit is turning the TV off due to excessive current flow. The excessive current flow is most likely the result of a problem in the HV (High Voltage) section of your TV. This could mean that the Horizontal Output Transistor or the Integrated High Voltage Transformer has malfunctioned (developed a short circuit). I would advise that you let a qualified TV technician work on the set due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | Televison & Video
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Oct 28, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Red-Orange Screen
If the screen flashed when the TV made a popping sound, then I would suspect an intermittent heater to cathode short in the picture tube. When this happens, it usually takes out one to three output IC packs located on the CRT drive board. Even if you replaced the defective output packs which are soldered in and attached to metal heat sinks to restore the picture, the CRT could short again and redo the damage. For a 20 inch screen it is probably not worth repairing.
Dec 04, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Your set migbe missing the high voltage that lights up the picture tube,you need to check for loose conections starting at the horizontal drive transistor and transformer ,then check the horizontal output transistor for short,it needs to be checked with a meter if the output is shorted it probably open a safey fuse or resistor to prevent more damage.If you are familiar with tv service this will give a place to star but if you are not too familiar be safe and seek the help of a servicer.Let Us know if you need more information.
Oct 14, 2006 | Sony KV-36XBR400 36" TV
Televison & Video Logo
174 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
