Question about Electrolux Washing Machines
I have Electrolux EW 880F washing machine that won't spin how can I fix it
  • Electrolux Master
  • 5,323 Answers
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, motor coupler, brake assembly, transmission, and mode shifter or actuator. one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
I have Electrolux EW 880F washing machine that won - belt broken beltwasher motor maytag amana-r0vmhnqx3ofapyttmvvmotan-4-0.jpg
Posted on Apr 17, 2017
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Jun 21, 2016 | Electrolux Washing Machines
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
Washer will spin will not agitate
Let me know what kind of washing machine are you having an issue with.So I can help you.
j gomez
Feb 08, 2015 | Washing Machines
Problem with electrolux washing machine
draining pipe its too low. check this link:
http://applianceguru.com/washers/drain-min.jpg
Aug 26, 2012 | Electrolux Washing Machines
Hi, I have and Electrolux EW 880F front loading washing machine. The wash cycle and spin cycle have stopped working and the 'end' light flashes 5 times. what does this code represent?
(pre-typed to save time- common problem!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 24, 2011 | Washing Machines
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
I am looking for the user guide in English of an Electrolux EW 1475 F washing machine thanks for your help tmarin59@yahoo.co.uk
You can download the manual from here
ELECTROLUX service manuals and owner's manuals download.avgnotice { width: 320px; font-size: 7px; line-height: 7px;}.avgimage { height: 7px;}.avgborder { border-color: #00A120; border-style: solid; border-width: 0 3px; font-family: Arial, Helvetica, sans-serif; font-size: 10px; line-height: 13px;}.avgsep { border-color: #C0A8A6 #C0A8A6 #FFFCF7 #FFFCF7; border-style: solid; border-width: 1px 0; font-size: 0px; line-height: 0px;}.avgtop { text-align: center; background: #F4FBF4 repeat-x url(chrome://searchshield/content/background_top_green.gif); padding: 0 5px; height: 30px;}.avgmiddle { background: #C3E5CA repeat-x url(chrome://searchshield/content/background_middle_green.gif); padding: 5px 10px; word-wrap: break-word; overflow: hidden;}.avgbottom { background: #00A120; padding: 10px 5px 0 10px; border: 1px solid #00A120;}.avgbottom td { font-size: 10px; color: #ffffff;}a.avgbutton { color: #0000ff; display: block; padding-top: 3px; width: 69px; height: 20px; text-align: center; background: no-repeat url(chrome://searchshield/content/click_here_green.gif);}.avgtitle { color: #00A120; font-size: 11px; font-weight: bold; margin-bottom: 8px;}.avgnote { font-size: 9px; font-weight: bold; padding-top: 5px;} --> Safe: This page contains no active threats. Explanation:
It is safe to proceed to this page.
Domain:
IP Address: 193.109.91.139
Owner:
   Name:
   Address:
   Country Code:
Scanned on: 03/27/09 10:45:13
(0.66 seconds to scan this page)
Ratings are provided by AVG. Site owners please contact AVG Technologies for questions. Keep up to date with the latest AVG news and updates. Visit the AVG website.
click here Get our most complete protection against online threats. Get AVG Internet Security today. Find out how. click here ')" id="XPLSS_1158028860U1" src="chrome://searchshield/content/safe.gif" border="0" hspace="5" />but it will cost 9.99.You can download it for free from other sites but they only have the french version.
Mar 27, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
