Question about Hobart H600 Stand Mixer
Electrical connection of hobart h600
Hi everyone, i'm an electrician and i am running new 3 phase wiring for a hobart h600 mixer but my client does not have this equipment on site yet so i cannot check whether the mixer needs 3 phase and earth or if it needs 3 phase, neutral and earth so i can select the correct cable for job. I contacted hobart who said it is 3 phase and neutral but the guy i spoke to didn't really seem like he knew what he was talking about. If anyone has any ideas it would be much appreciated.
  • 3,600 Answers
It requires 3 phase with ground it is a four wire system
Posted on Jul 24, 2009
Hobart Mixer H 600 is 3 phase and ground. I am not an electrician but I need to connect my Hobart mixer. Can you guide me in the right direction? I have 3 wires coming out of the wall and 4 wires (3 live and 1 ground) coming out of the Hobart mixer. How do I connect wires (they are all the same color)?
Posted on Jul 24, 2010
What direction should a Hobart H600 mixer rotate?
Check Rotation (Three-Phase Machines Only)
Three-phase machines must be connected so the planetary rotates in the direction of the arrow on the
Drip Cup. To check rotation:
Set the gear shift lever on 1.
Apply power to the mixer, set the Electro-Mechanical Timer on HOLD; or, if equipped with a
Programmable Timer Controller, set it on [ -- : -- ]. With the Bowl Support all the way up,
momentarily run the machine by pushing the START and then STOP buttons.
If rotation is incorrect, DISCONNECT ELECTRICAL POWER SUPPLY and interchange any two
of the incoming power supply leads.
Oct 12, 2017 | Hobart Food Mixers
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Sep 05, 2011 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
Seemingly well maintained H600 mixer only runs in reverse...
whoever wired the mixer in , hopefully 3-phase made a mistake on the incoming pwr to term block or the contactor switch any 2 leads this should reverse rotation of the mixer
Nov 04, 2009 | Hobart H600 Stand Mixer
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
May 31, 2009 | Hobart H600 Stand Mixer
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
Hobart H600 Stand Mixer Logo
876 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
