Question about Dryers
660 dryer Lights on not working.learning so if the fuse had gone this would trip the fuse box? Nothappened prevreplaced the hook/latch ok door dropped hence no connection altered screws all ok Now?
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
jaysonemanme
  • 500 Answers
SOURCE: Need detailed diagram of 1998 latch mechanism to remove connections from it
there is no diagram... the latch is also a non-servicable latch, so if your problems in the latch- it needs a latch. i would look more closely at the outside door handle itself as i have seen a few of them break on the E series vans.you may be able to get detailed instructions thru autozone.com or @ autozone. hope this helps and good luck
Posted on May 29, 2009
SOURCE: 2006 GMC Sierra 2500HD 4WD trailer light connection fuse blown?
under the hood on drivers side right behind the battery. Will be marked trailer light left sand right.
Posted on Jun 27, 2009
SOURCE: I have a 2006 Cadillac
Would like the solution as well. Dealer says it has to be drilled out.
Grabbing the squarish "loop" under the handle down and away using needle nose pliers doesn't unlock the door
Posted on Nov 30, 2010
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
Dryer will not start, no noise, nothing
It is as if the door was open right? With the door open the dryer is dead in the water. Closing the door trips a switch. Could be that switch has gone bad. If that turns out to be ok then look for reasons why the dryer would be dead. Take the vent pipe off and inspect for lint buildup. If the vent is blcked and the dryer temp exceeds 350 then the dryer fuse will melt and because it is tied in with the door switch it is as if you opened the door when that fuse melts. How to check it:
Jul 20, 2011 | Dryers
The Frigidaire dryer will not start up. The push button and the trip works. Could it be a door problem?
Yes, it is possibly a door switch. On some units, there is also a fuse. Try the door latch first. '(bridge it out temporarily)
Sep 21, 2009 | Frigidaire GLER642A Electric Dryer
Blown fuse?
you have a failed door latch . you will have to remove door panel and window regulator to get to the latch. you can check this by closing all doors then open one by one when you open one see if you dome lights come on if they do that latch is ok. common issue. water gets into the electrical portion and kills it. most likely just drivers door it is opened the most. 1-2 hours at a shop and problem should be gone.
Aug 14, 2009 | 2000 Volkswagen Jetta TDI
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like its blown a thermal fuse.Its under warranty if you just bought it.You need to set up a repair while you have warranty.
May 21, 2008 | Dryers
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Dryers Logo
Top Dryers Experts
