Question about Tablets & eReaders
Is there a tablet that i can teake it is bad - Tablets & eReaders
I have added my keyboard to my Mobicel tablet but it doesn't want to connect so what should I do?
The micro USB port is bad or the keyboard is bad. Plug the tablet into a pc to see if the computer can see it. If the computer can see it then the keyboard is bad.
Mar 25, 2018 | Tablets & eReaders
My tablet won't charge
First try to charge it with a different charger, and test the factory charger on another device (you tablet may have the common micro USB connector). This will test if the charger or cable are bad. But if the tablet will not charge with a different charger and cable, and it is still covered under the factory warranty, return it for a refund or a replacement.
I have repaired many tablets with a bad charger port, and it seems to be either a poorly designed connector, or an open wire inside due to pushing in too ******* the cable into the port.
if you cannot replace the tablet, maybe you can find help from someone who can open the tablet and fix the charger port.
Nov 27, 2017 | Tablets & eReaders
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
Why did tablet stop working?
Charger is no longer working or you have a bad tablet. Using a voltage meter make sure that the charger is outputting current to the tablet.
If it is, then you have a severe issue. Hope that the receptacle is bad or has a bad connection. But .....................
Feb 15, 2016 | Tablets & eReaders
Is not charging
Well it could be many things like bad outlet to bad charger but my best guess is the medal piece inside your charger is not touching the one in the tablet to charge it. Try replacing your charger if that don't work take it in your tablet to get fixed its most likely the one in the tablet. Thing wear down with use. I should know I just had mine fixed too! Good luck hope I helped.
Aug 11, 2015 | Samsung Galaxy Tab 10.1 16GB WiFi Android...
My tablet is not charging
Does the tablet power on when plugged in?
Have you tried a different power outlet, or a different power adapter?
Does the connector on the tablet seem loose or will the tablet charge if you hold the charging cable firmly to the charging socket?
Depending on your answers, it could be a bad charging port on the device, or a bad power adapter/cable, or a problem with electrical outlets. The remaining option would be a battery problem.
I post on behalf of HP.
Jul 01, 2015 | Tablets & eReaders
How to fix a imito tablet that wont turn on?
When you are sure the battery is fully charged I don't think there is much you can do.
Lots of things, like a bad charger, a bad cable, bad connectors and a bad battery, can be the cause the tablet does not have enough power. But when there is enough power, the on / off switch cam be defect, or any electronic part in the tablet could be. Without the tablet i my hands and measurement tools to verify everything it will be impossible to tell what is wrong. Take it to a repair centre, but before you leave it, ask what they charge for the diagnose. Not sure you can swap the battery and how difficult it would be to get one?
Perhaps that is the problem, but don't take my word for it.
Sep 06, 2014 | Android Imito Im7 2.1 7" White Tablet Wifi...
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
