Question about Grilling
My Westinghouse Freestyle is not heating up enough to cook my roast
5 Suggested Answers
SOURCE: LId to 6 quart crock pot shattered
I have a 5-quart crockpot that cracked across the bottom. I've been using the crockpot liners, and they seem to work very well. No leaks, etc., and food seems to cook just as well as before the crockpot cracked. The liners sure do make cleaning up a lot easier, too!
Posted on Jan 04, 2008
SOURCE: Seems like my thermostat is
Call a fridgy, use a multimeter to see if the thermo contacts open and close or see below:
These parts need to be ordered in from Adelaide, that is where the large warehouses for Electrolux are. The part number for the thermostat is 1416543 @ $77.00 each,
the heater 1413084 @ $28.50 each. Allow about $18.00 for Postage and Handling
Posted on Feb 22, 2011
SOURCE: Westinghouse Freestyle 662 Oven Fan &
its the element
Posted on Sep 02, 2011
AndrexT
  • 16749 Answers
SOURCE: I want to cook a rib roast in the pressure cooker. How long to cook? This is NOT a pot roast!
Please don't! You will ruin the prime roasting joint in a piece of beef rib. If you want to boil meat in a pressure cooker, use Tri-Tip or Topside. Roast uncovered in the oven for 1 hour and 15 minutes. Rest for 15 minutes, remove from the bones and carve. You can roast the bones with BBQ sauce as a snack another day.
Happy Easter
Andrew - Master chef qualified 1971.
Posted on Mar 27, 2016
Cooking time for 3.91 lb. chuck cross rib boneless roast
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
Jan 05, 2018 | Grilling
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 | Cooking
How long to cook 3lb chuck roast in 350degree oven??
Dec 24, 2017 | Grilling
How long do I bake an 8lb shoulder pork roast?
hi Dianna.
Roast in a preheated 500 degree (F) oven for 20 minutes. Reduce heat to 300 degrees and roast for an additional 30 minutes per pound. Total cooking time for an 8lb roast should be about 4hrs and 20 minutes. Remove the pork roast from the oven and let rest for 30 minutes
How long do bake an 8lb shoulder pork roast Google Search
Dec 14, 2017 | Grilling
My new westinghouse oven just took 3 hrs to cook a 1.8kg chichen and the roast potatoes now browned at all.
The problem may be that you are trying to cook a whole chicken in a microwave oven.
Aug 28, 2017 | Westinghouse Microwave Ovens
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
Cooking a 22.8 lb standing rib roast
To have this cooked to a medium will be about 18 mins a pound. Cook a shallow pan at 325 for that amount of time. If you would like a crispy exterior then heat the oven to 450 put in the roast for about 20 mins then reduce heat back t 325 to complete cooking. Before you start rub the entire roast down with equal amounts of salt and pepper. LOTS OF EACH.
Dec 24, 2015 | Kitchen Ranges
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
Jan 24, 2013 | Kitchen Appliances - Others
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
I am cooking a roast and i just need to know how much water to put inside the cooker.
1/4 cup is enough. Roast has a high moisture content and will produce a lot of liquid for gravy! I'd only use more when I am cooking potatoes in the same roaster with the meat, then I would increase to a cup. Cover the roast tightly with foil or a good lid.
Apr 12, 2009 | Crock Pots & Slow Cookers
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
