Question about GE WBVH6240F Front Load Washer
My 2 year lold front load GE washing machine has developed a lot of mould in the rubber gasket on the front of the machine. I have tried to bleach it but the mould remains. It causes the cloths to have an unpleasant smell if they are not removed from the machine right away. What do I do to get rid of the mould? Can the front rubber gasket be removed and how do you do this? If I need to order a new one to replace the gasket, where do I order it from? Looking forward to your reply. JS Canada
  • 115 Answers
On my lg, there are two small drain holes in the folds of the gasket that got plugged up with lint and stuff, unplug them if you have them. also i leave the door open after wash to let it dry out
Posted on Jul 25, 2009
How to get rid of black mould?
Do a long hot wash, add bleach. Stop using fabric softener. If the rubber boot on the door (Front loaders) has been stained with black mould, you wont get the stains out. It will need a new gasket.
Mar 20, 2017 | Washing Machines
Mold on inside rubber band and mold in soap dispenser and in back of soap dispenser.
This is quite a common problem and difficult to avoid unless you leave the drawer and door wide open all the time when the machine is not in use (which isn't very practical for most people!). You will find that painting the mould with thich household bleach and leavingit overnight will remove most if not all of the mould. If the first night doesn't get it all out, paint it up again for another night.
Note: You need to be very sure that you have washed all the bleach away after you have done this, so as not to bleach any clothing that then goes into the machine. ash the drawer and rubber thoroughly by hand, paying particular attention to the partially concealed area at the bottom of the rubber gasket between the inner and outer drums. I would also suggest that it is worth putting the machine on a hot wash while empty, to clear any last remnants of bleach.
Aug 25, 2011 | Kenmore HE2 Plus Front Load Washer
I have a 18month Electrolux 8kg front loader which has mould on the bottom part of the rubber seal. I have always kept the door open after every wash but the mould has set in. I have tried wiping it with...
You will find that wiping it dry, then painting it with thick household bleach and leaving it overnight will have an excellent effect on the staining. The rubber will tolerate the bleach without any problem. If one night doesn't quite cut through the mould, treat again the following night.
Just remember to wash the bleach away thoroughly, so that it doesn't affect any garments in the next wash!
Jul 29, 2011 | Washing Machines
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
GE WBVH6240F Front Load Washer Logo
194 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
