Question about The Health & Beauty
To find if my pressure at the moment is high 164/79 I am 79 years old.not feeling good in chest and arms
  • The Master
  • 1,929 Answers
No, that is not considered high at all, but your symptoms sound like you should see a doctor immediately or visit emergency. Don't delay. If you have anything else like the below, call paramedics, seriously:
shortness of breath
nausea
vomiting
sweatiness
dizziness
Posted on Apr 16, 2017
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
Jun 14, 2017 | Kenmore Refrigerators
Swollen ankles very painful high blood pressure sometimes get pain in chest and down left arm what could be the cause Thanks
Fixya is an advice forum for do it yourself professed people. If you need medical advice seek a doctor or ER
Feb 27, 2017 | The Health & Beauty
I am a 80 year old woman blood pressure 146/77 pulse 98 is this too high/
You pulse is way high (should be about 75), your blood pressure is high as well (anything over 145 is high). Please see your doctor ASAP!
Nov 01, 2016 | Cars & Trucks
If blood pressure is 193 over 97 what should I do what is happening
That is high. Make sure you are taking it properly as per directions. The cuff is on your arm with the artery mark in the antecubital fossa- the space where your arm bends. Rest on a table top at chest height, make sure it's on properly- snug, deflated, then push the button or inflate. Always check with the Dr. or nurse if you've purchased a new machine so they can check if calibrated and accurate and of course, that you are healthy. Assuming that the meter is functioning properly, that reading is high and abnormal and you should get checked ASAP
Aug 20, 2014 | Health & Beauty
Readings are too high compared to doctor's readings
There are several reasons for 'too high' readings; the cuff is too small for your arm, the muscles of the arm are not relaxed (squeezes on the blood vessels along with the cuff), arm not elevated to about mid chest level, BP tkaen before 5 minute sit/rest.
You can take your cuff into the doctors office to have it checked by the nurse and compared to theirs, rest 5 minutes ther as well befor taking BP. Their cuff could be too big for you and so would give a false low reading.
If the calibration is off, you will have to return it to the manufacturer - check their web site or call the customer support line.
Congratulations on taking an active role in your health care!
Dec 01, 2010 | Homedics Automatic Arm Blood Pressure...
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Outside freezer storage
as long as it is just a freezer, not a fridge-freezer, should be no problem
Nov 26, 2008 | Magic Chef 7 cu. ft. / 198 liter Chest...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Health & Beauty Logo
Top The Health & Beauty Experts
Elliot Kelly
Elliot Kelly
Level 1 Expert
Don A
Don A
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
