Question about Canon Office Equipment & Supplies
Facing machine roller on right side, back, will not allow paper to go through when copying. I can't use to copy.
    President:
  • 1,723 Answers
I've seen this with printers. Try putting a slight bend in the right corner of the paper. Bend it down. I'm not kidding it WILL make a difference.
Posted on Jul 24, 2009
How do I load a document in my fax Machine
If you are laying your original on a glass, like in a flatbed scanner, you lay it face down.
If your fax works like my printer, the printed surface is on the bottom tray face down. It It gets sucked into the printer under the roller, around the back of the roller and comes out in the upper tray over the roller and face up. You laid the paper face down.
I hope this might help resolve your question.
Oct 15, 2014 | Premium New Brother LC61 Series Combo Pack...
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Sir/Mam,
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
Oct 05, 2013 | Konica Minolta 950-281 Genuine Konica...
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
A copy has toner all over the right side on the paper.
Are you mean that toner isnt baked enough? If yes then you have problem with fixing roller bushings.
But if the toner is like printed, change blade and drum.
If the toner is like spiled on copy, vacume and clean the machine
Jul 01, 2010 | Sharp AL 1631 Copier
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Jan 28, 2009 | Minolta EP4000/5000 CS/PRO Copier
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Paper feed error
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers c00109674.jpg
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Jan 12, 2008 | HP PSC 1210 All-In-One InkJet Printer
Check Rec Paper
First power off the machine. Facing the machine from the front, remove the rear tray extension that holds the paper and "feel your way" down into the right side of the of the back paper tray. You should feel a out-of-round feed roller. With a little effort you can rotate this around. Take a terry like cloth and dampen it with water and clean this roller. Before puttin any paper back into the tray, turn the machine back on so the paper feed assembly will return to the home position.
Jul 15, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
59 people viewed this question
old marine
old marine
