Boxlight CD-725C TEMP light comes on and unit shuts down afer 10 minutes. Unit has about 1200 hours on the bulb. Seconds before the unit stops, at least one of the fans slows down.
The reason why the temp comes on because the fan is start slow down, so the bulb produce a lot of heat. Once the maximum temp reach, the temperature sensor will become inactive. So boxlight shutdown. First you need to replace the fan, or check the supply dc voltage going to fan if it is stable.
Before going through the expense of replacing the fan(s); I removed the covers, bought a can of compressed air and blew out the entire interior, paying special attention to the fans. The projector has worked flawlessly for almost two months. The fix took less than seven dollars and about 30 minutes to complete!
I need to know where to find a replacement color wheel for my BenQ PE7700 projector. I can't believe...
(More)
I need to know where to find a replacement color wheel for my BenQ PE7700 projector. I can't believe I can't find any place online that carries repair parts. I know how to repair the projector myself and do not want to take it in.
I have a Panasonic Projector that I use as a TV. It is model number PT-LB10U. Recently a blue cloud...
(More)
I have a Panasonic Projector that I use as a TV. It is model number PT-LB10U. Recently a blue cloud appeared in the top left corner of the screen. It is growing bigger all the time and is beginning to take over. I replaced the bulb, still there. Any ideas? What's next?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
