Question about ZTE Cell Phones
My phone is locked with a Google account it's ZTE 4G
My phone is broke and this one is the exact same one but I can't get it unlocked because there's a Google account on it and no one remembers the Google account
  • 6 Answers
SOURCE: The screen is locked
If you do not remember your google account information and cannot get it through the google site on a PC the only way to gain access to the phone is to perform a master reset to the device. You will lose any unsaved data so it is extremely important to write down your google account information.
Posted on Feb 04, 2009
SOURCE: put my x10 on charge , had lock on, my daughter
sigmatelfxdmobile keypad problem
Posted on Sep 02, 2010
ishaqazmi
  • 80 Answers
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it. samsung_i9000_galaxy_s_hard_reset.png
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
Posted on Oct 17, 2010
  • 90 Answers
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Note: Factory reset will not remove the data and files that are in your phone's microSD card. Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button. Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Posted on Mar 27, 2011
sourcecode20
  • 93 Answers
SOURCE: my phone is locked, saying
Best Solution;
1. Power off phone
2. Press and hold Home Button ( middle ) + Volume Up + power on button
3. Wait for 5 second until Android System Recovery menu appear
4. There are 4 options
reboot system now
apply update from sdcar
wipe data/factory reset
wipe cache partition
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
Posted on Jan 20, 2013
My Android zte prestige is pin locked. How can i unlock my pin?
Without a Google account password or username or a connection to the internet, you will not be able to unlock a ZTE Android phone without performing a Factory Reset
Nov 29, 2016 | ZTE Cell Phones
PUK CODE FOR MY ZTE LEVER 4G SO THAT I CAN UNLOCK MY SIM CARD
PUK codes are only available from your service provider
call them on another phone provide proof that you own your account and they will give it to you
Jan 30, 2016 | ZTE Cell Phones
Locked out of my zte sonata 4g phone after to many
Sir, if your phone's 3G or wifi is enabled and it access the internet then you can unlock it by providing you gmail account. if no, then please hard reset it from bootloader
Sep 24, 2014 | Cell Phones
How do I unlock my Sonata zte 4g after too many pattern attempts
Sign in to your google account to reset the pattern lock.
May 24, 2014 | AT&T Cell Phones
Pliss, i need to unlock my phone ZTE N910
You can get the unlock code for your ZTE N910 phone from SuperUnlockCodes.com and unlock your phone from Network lock easily.
Jan 10, 2014 | ZTE N910 Anthem 4g Black Premium Silicone...
How do i pattern unlock zte racer 2?
On the locked screen, if there is an Emergency Call button, press this, then enter *983*987# into the dialler. Follow the steps to do a factory default
Dec 02, 2013 | ZTE Cell Phones
I need to unlock my phone.. It says use a pattern but i never put one in there and also when i have the option to log into my gmail to fix ot.. Ot says invalid. How do i get the screen unlocked
If you have forgotten the screen unlock pattern, you have up to five attempts to try and unlock your phone. If this fails, you can unlock HTC Inspire 4G by entering your Google Account user name and password.
  1. On the unlock screen, attempt to enter your unlock pattern five times.
  2. When prompted to wait for 30 seconds, tap OK.
  3. If the display goes off, press the POWER button to turn the display back on, and then press the bar on the lock screen and slide your finger down to unlock the screen.
  4. Tap the Forgot Pattern button in the lower right corner when it appears.
  5. Enter your Google Account name and password, and then tap Sign in.
You are then prompted to create a new screen unlock pattern. If you no longer want to use a screen unlock pattern to secure your phone, tap Cancel.
Follow that instruction step by step and if you success you get your HTC unlocked, remember read that instruction carefully, if you did wrong step you will not allowed to enter your google account.
Sep 05, 2011 | HTC Inspire 4G Smartphone
Cell Phones Logo
29 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
