My vx426 g45 hand held will only receive and not send I hit the call butten and it beeps once
Wv 344 child lock need this turned off please
Press and hold the 'Child Lock' button for 2 seconds. You will then hear a beep and the child lock should be off..
Mar 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
Cnnot send or receive mms on samsung gt-i9000
Hi there this problem is very easy to solve have fixed both my sons and partners phone today..Ok this is how you do it..
Step 1.Go to settings then wireless and network then mobile network settings..
Step 2.Make sure Use packet data has a green tick..Then go into Access point names..
Step 3.Now you want to select Internet which is the first one then hit left hand menu button so you can delete APN once you delete it go to mms second on the list and delete it the same wait if you have more access point names in here delete them too..
Step 4.Now hit the back button once theres no more names in the list to where it says Access Point Names then go back in again and hit left hand menu button and you want to touch on Reset To Default...It will reset the settings for you and thats it DONE you will be able to send and receive mms and surf the internet hope this helps need anymore more help email me on nikkialliston@hotmail.com :)
Jan 20, 2011 | Samsung Galaxy S GTI9000 Smartphone
I can't send MMS from my galaxy s GT-I9000 , Please help !
Hi there this problem is very easy to solve have fixed both my sons and partners phone today..Ok this is how you do it.. Step 1.Go to settings then wireless and network then mobile network settings.. Step 2.Make sure Use packet data has a green tick..Then go into Access point names.. Step 3.Now you want to select Internet which is the first one then hit left hand menu button so you can delete APN once you delete it go to mms second on the list and delete it the same wait if you have more access point names in here delete them too.. Step 4.Now hit the back button once theres no more names in the list to where it says Access Point Names then go back in again and hit left hand menu button and you want to touch on Reset To Default...It will reset the settings for you and thats it DONE you will be able to send and receive mms and surf the internet hope this helps need anymore more help email me on nikkialliston@hotmail.com :)
Oct 12, 2010 | Samsung Galaxy S GTI9000 Smartphone
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Kenmore elite calypso washing machine that won't spin and drain, it has an error code of F-3, but I can;t find my manual. any help
After setting up washer I hit the start butten, washer filles up and befor it will start it will start to beep and the lights flash and I have to hit the start butten agin befor it will start to wash.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
BT Freelance XD 5500 Trio phone. Continuous beeping
Solution from BT helpcenter:
Thank you for contacting the BT Helpdesk.
To turn off the message alert beep: Hold the left-hand <<SKIP button on the main base until the voice says "message alert off"
Jul 14, 2008 | Lands Phones
Aquatech Sport Chronograph Watch
quickly press the bottom-left button twice.
then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
Dec 20, 2007 | Watches
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
