Question about Daewoo Refrigerators
Can an old Daewoo Mutiflow nofrost fridge/freezer be regassed or repaired agent say it is the electronic board and cannot get replacements but the freezer section works not fridge section ?
  • 813 Answers
Hi,have a look on (espares.co.uk 08449777888) this is where I got my electronic board,hope this was some help.
Posted on Apr 15, 2017
Freezer lights not working tried bulbs in fridge area and they work so its not the bulbs
Then it's the freezer door switch that controls the light. Although, modern fridges have electronic control boards designed to make your life miserable. Instead of a simple switch with a wire to a light bulb, you may have an entire computer board controlling it. The boards are _always_ expensive as heck. You can try applianceparts.com for replacement parts for your specific model.
(It was the words "Professional Series" that gave me "pause" regarding the electronic wallet cleansing you may have to deal with. I'm sorry, but I'm an old appliance tech that has lived long enough to see these appliances become unnecessarily too expensive to repair a problem that would otherwise have been an incredibly simple and cheap to repair... and frequently not even need a new part. Technology does no favors for owners regarding appliances. It is a cheap way out for the manufacturers because electronic circuit boards made in China are cheaper than the electro-mechnaical devices they replaced, yet cost many hundreds of dollars to buy a replacement circuit board; which is quite literally a scam designed to make you buy a new appliance).
Apr 06, 2016 | Viking Professional Series VCBB36 Bottom...
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
Daewoo nofrost multi flow freezer
Sounds like a gas problem if its new under warranty get it replaced.If its old dont repair,replace it.
Sep 04, 2014 | Polder THM560N FridgeFreezer Thermometer...
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
We have a FRS-U20FA
The water dispenser tube has a low wattage element to prevent the water from freezing in the tube. its normal. Check to see if the evaporator fan is running. Open the freezer door and when the fridge is running, press the switch on the side wall. The freezer light should go out and then you should hear the fan running at the back of the freezer compartment. Common symptoms of a failed fan is ice growing down the back of the freezer compartment , poor refrigeration in the food compartment and partial or poor freezing of food in the freezer. If the fridge is less than 2 years old, it will be under warranty. (Contact Castel Electronics in Melbourne 13
00733962) If its over, they can give you the name and number of a local agent. There are a lot of bits and pieces to remove to get to the fan on an ice and water model, also the rear panel inside the freezer should be removed to make sure ice hasn't blocked the air ducts. If you are not confident in doing it, get one of their agents to sort it out. Cost of fan motor, call and labour should be around $200 to $220
Dec 26, 2013 | Daewoo Refrigerators
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
Amana SBD 522VEBONY - fridge freezer is not staying cold -
If your freezer works after regassing...and after sometime the problem occurs again. It seems to me that there is leak on the pipes in which where the gas runs, that is why it runs for sometime after regassing, after some time the gas that was loaded during regassing leaked through the atmosphere and the problem occurs again. It would be better if you replace it with a new fridge.
Hope this idea helps.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
35 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
