My Toshiba aw 1190ss won't take in water and the wash and rinse cycle doesn't work
SearsTechToo
  • 261 Answers
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Posted on Nov 01, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 713 Answers
SOURCE: water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
The rinse cycle won't spin out, it starts but doesn't "spin up" and just runs for ever if you let it.
Possible that the program controller unit is a suspect. So intitially check the inlet valve , check for water flow, if not remove and check INLET valve. after water filling the motor must start, if not the level sensor or the program controller is a suspect. Also if after wash if there is no drain then the drain pump must be checked.
Check the voltage outputs to confirm if the program controller works to the cycle.
Sep 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
As soon as it gets to the rinse cycle it doesn't fill up water, what can i do?
If the only time that it won't fill with water is the rinse cycle is is probably either in the timer or control board.
Have you tested it on all the the setting to determine what works and what doesn't? Will it work on permanent press but not delicate; that type of troubleshooting.
Jul 16, 2011 | Washing Machines
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
