Question about Echo Computers & Internet
Echo is saying it has lost its connection yet I see it is connected to my router. Is the network at fault?
I have two devices and both are giving the same error at the same time so I suspect it is the Amazon cloud that is at fault. Does this make sense?
    Top Expert:
  • Echo Master
  • 51,198 Answers
Ye s
amazon like all web users use a web server (IP address) that can crash at times and break internet connections
not to panic at this point in time as they are normally attended to automatically or by technicians maintaining the server
give it a few hours to reconnect or if longer call amazon by phone and ask about the cloud server
Posted on Apr 15, 2017
SOURCE: Connecting to Internet
how can i find out what the password or pin # is for the router
Posted on Jan 25, 2008
SOURCE: 3 problems writting on hd, drop connection n download master
Use a FAT32 Formatted partition (32GB) on your external USB Harddrive as the main Master Download Area. To do this, connect the drive to the PC by USB and re-partition the drive in sections with the disk manager. 32GB for the FAT32 and the rest in NTFS. Re-connect the drive to the WL500W USB and the FAT32 partition will be recognised automatically by the Router. Linux users can use the full HD drive if they format the drive in Ext2/Ext3. Correctly formatted USB memory sticks with a capacity of 32GB are better suited for this un-attended (low power) dowloading. You can use a (FAT32) 8 Gbyte stick also !
Warning !
Using only NTFS partitions will make the drive read-only and useless for un-attended downloads by the WL500W. Unfortunatly this is the case with 100% of all new availbale drives (>500GB) - So RE-PARTITION it wisely !!!
What about Queing (Waiting) ?
It waits for the connection and if bandwidth is available it starts the download. If files are missing on a server or the address is invalid an error is risen and the link is aborted or deleted. Many BitTorrent files are invalid or have nobody seeding. Waiting is therefore the best option.
Posted on Jul 08, 2008
SOURCE: HP LJ 3055 Toolbox Not Connected
It sounds like a Firewall configuration issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&objectID=c00192126
Ports 5225-5226 need to be open on the router and on your machine.
Posted on Nov 13, 2008
  • 20 Answers
SOURCE: Internet radio will not connect to recognized WiFi
Try going into your router configuration menu, and opening the network so that any device can connect. Disable any passwords and all of that, and see if it will connect in that way. This doesnt sound like a problem with the Stiletto, rather a problem with the configuration of the wireless router. Maybe call the tech support for the router also.
Posted on Dec 20, 2008
SOURCE: LG Incite wifi loses connection when using browswer
Find Proxy Manager select <Disable Proxy> and hit <OK>
Proxy Manager is located in the Tools folder
That weird button (four dots with a finger and hand) on the bottom right
Calculator Tab
bottom right Suitcase looking icon called <Tools>
Or you can find the Proxy manager the hard way by going into
File Explorer>My Device/Windows/ProxyManager.exe
Posted on Apr 19, 2009
Setup Amazon Echo Device
Step 1. Download the latest version of Alexa app. Go to the app store and search the "Alexa app" and install it.
Step 2. Turn on Echo device.
Step 3. Then connect Echo device to Wi-Fi network. Enter the password and username correctly. If your echo device does not connect to the Wi-Fi network. Then unplug the device and plug the device again.
Step 4. Now you can use Echo device.
Mar 22, 2018 | Amazon Computers & Internet
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
How do I register m echo dot?
Download Alexa app and sign in
Turn your echo dot device and place in a central location
Connect echo dot to a Wi-Fi network
Talk to Alexa with say any command.
Mar 22, 2018 | Echo Computers & Internet
How do I register my echo dot
possibly thru amazon website .
Mar 22, 2018 | Computers & Internet
I just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Jan 25, 2017 | Internet Computers & Internet
Why can't I connect to home WIFI?
Firstly, I would reset the router by removing the power for 5 minutes and then try again.
Jan 21, 2017 | Samsung Computers & Internet
Echo. Cannot activate have put in wifi network and password can you help?
You must first connect directly to the Echo and configure. The as with any Wifi device enter the SSID and password/key. If your router has a guest mode, set-up with no password to see if it will connect that way.
Dec 29, 2016 | Computers & Internet
REGISTERING AMAZON ECHO
To learn more, go to Connect Echo to Wi-Fi. Tip: If your Echo doesn't connect to your Wi-Fi network, unplug and then plug the device into a power outlet to restart it. If you still have trouble, reset your Echo to its factory settings and set it up again.
Set Up Your Echo - Amazon
https://www.amazon.com/gp/help/customer/display.html?nodeId=201601770 REGISTERING AMAZON ECHO Google Search ..try this out
Dec 01, 2016 | Computers & Internet
HP DeisgnJet T770 - 24 InchThe network link light is solid amber. There is not activity indicator illuminated. The device will print all internal demo prints but cannot access from the network. I have...
not sure this will help but heregoes,
If you can see that the plotter believes there is network communication when no network cables are connected then the fault must lie within the plotter. ( I've had Carriage PCA's give me a similar fault with network issues) and the only way forward is to replace 1 part at a time using logical faullt deduction to identify the next part.
If you see an orange com light only after you connect the lead the network card is telling you there is a com fault in the line to the router/switch ( make sure your NOT using a crossover cable if connected to a router/switch as this is often the case for this fault) replace the cable then switch/router
if the plotter has been defaulted then it should be set to DHCP and should automatically find a working IP address and subnet,
another way of checking the plotters external comms device is to connect via USB, which may help decide if the replacement Main PCA was functional to begin with,
My experience would suggest in order the fault will lie:
external Net cables
external router/switch comms
Formatter
Main Pca
Power supply ( comes with Main PCA)
Display panel
and finally the Carriage Pca,
thankfully the ISS Pwb has never given me any issues.
Good luck
Mar 09, 2014 | HP Office Equipment & Supplies
Computers & Internet Logo
143 people viewed this question
Top Echo Computers & Internet Experts
Computer Links
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you an Echo Computer and Internet Expert? Answer questions, earn points and help others
