Bosche classixx 1200 express suspension metal sleeves rock from side to side
Both metal sleeves covering the suspension bars rock from side to side, is this normal?
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric softener dispenser no longer works on my Bosch
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
Posted on May 20, 2009
SOURCE: Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
Posted on Jan 24, 2010
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a bosch 1200 classixx express. can you
Try this link:
http://www.bosch-home.com/us/bosch/customer-care/contact-us.html
It took me 45 minutes to even find the page. No wonder there are so many manual requests.
Kelly
Posted on Aug 24, 2010
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
I have a bosch classixx express 1200 washer and when its on rinse it makes such a loud noise and also when its on spin, its like a grinding noise. hope u can help.
The noise is relative to the motion and so the areas to check must be the moving parts of the washer. So shut down unit , disconnect power and check manually the movement of the motor, the rotor and the drum.
the bush can be worn out the suspension can be weak or the belt can be faulty.
your observation while the motor works is important.
Check these links below for some help :\
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 15, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Classixx 6 1200 Express washing machine manual
whay may nero 9 serial number it das not working? ma old S.N invalid
Nov 01, 2009 | Bosch Washing Machines
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx 1200 Express - metal got under the drum
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
