Question about Fisher and Paykel Ovens
How to set the oven for automatic cooking on a fisher and paykel saffron oven
textonor
  • 130 Answers
SOURCE: Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Posted on Feb 04, 2008
  • 417 Answers
SOURCE: wall oven on automatic with 0.00 flashing and will not go
You need to set the clock to the correct time and this should take it out of automatic mode, it should then work o.k
Posted on Nov 30, 2008
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
  • 51186 Answers
SOURCE: The oven light comes on but does not heat up and the fan does not turn on
function dial needs to be on bake I believe
Posted on Jun 09, 2015
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
Fisher and paykel clock problem on underbench oven N1528???
try pushing the left two buttons and the second to last button all at the same time
Nov 08, 2013 | Fisher and Paykel AeroTech OS302 Electric...
Fisher & Paykel OR90 Oven just turned it self off and wont work the only thing working is the digital clock.
sounds like its gone in to automatic mode,try pressing the left two buttons and the second to last buttons at the same time
Mar 18, 2012 | Fisher and Paykel AeroTech OS302 Electric...
How do I set the clock?
according to owners manuel push clock button and turn setting knob. go to this web sight to download or read the manuel
http://www.fisherpaykel.com/cooking/index.cfm?productUid=9A835408-BFF9-38F9-29262A3460B03423&section=supp
Jan 31, 2008 | Fisher and Paykel OS302SS, Stainless Steel...
Ovens Logo
29 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
