Question about Ovens
How to clean electric oven roof - Ovens
2 Suggested Answers
  • 250 Answers
SOURCE: How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Posted on Jan 07, 2012
Euromaid oven instructions
Try search engine
Jul 20, 2014 | Ovens
Cleaning roof of oven, does the can the element be removed
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Mar 24, 2014 | Bosch HBN 131560B / 131520 hot-air...
Dec 31, 2011 | Stoves 720EF Electric Double Oven
Heating element hangs down in Miele oven
Hi dose it look like something broke off on the top of the oven , usually they have a small bracket with a screw in it , do you even see a hole for a screw ?
Dec 12, 2011 | Miele H4780BP Stainless Steel Electric...
My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
after isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
Aug 24, 2010 | Zanussi Ovens
My grill element looks as if it has melted and
From the description you have given it would seem as if the element is'gone' i.e broken.
You will need to have it replaced before it does any more damage to the oven roof.
Jan 06, 2010 | Zanussi ZBF360X Electric Single Oven
How to clean roof of AKL 828 /1x
Buy a can of oven cleaner suitable for use in electric ovens and follow the instructions on the can. Its basically spray the aerosol foram and wait then rinse off or preheat the ovena nd do the same and depends on the brand that you buy. It is a bit smelly but does the job! Most supermarkets and domestic appliance stores stock these products.
Sep 29, 2009 | KitchenAid Architect Series KEBC208KSS...
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
The screws holding the grill element to the roof of my Electrolux oven have come out.They can be removed in order to clean the roof of the oven. According to the manual, it is easy to screw these back in...
Possibly held with self tapping scerws, and hole has enlarged, all you will see are 2 small holes if this is the case, then use larger screws..
If this helps, please leave positive feedback. Thanks
Nov 26, 2008 | Ovens
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
