Philips, 51pp9303H/17, picture fuzy, and green around edges? How can this be resolved
Slinteriors
  • 8617 Answers
SOURCE: convergence trouble philips mod 51pp9303h/17
STK392-120 you will need to replace both of them
Posted on Mar 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: My Philips DPTV345 Model# 51pp9303h/17
need to replsce the coolant in the CRTs ( picture tubes) very common problem with that model. You can get a kit caalled the Phillips CRT coolant change at the following link which contains the proper coolant along with an instruction CD which shows how to do the replacement .Its under the repair kit category. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
Ecollier2012
  • 3459 Answers
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Posted on Dec 15, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips Projection HDTV 51pp9303h/17
In your set you have three circuit boards.
The one on the far left is the SSB, middle board is the LSB, and the board on the right is the power supply board.
Try yanking cable 1516 that connects the SSB to the LSB. Its a small white ribbon cable.
Does the set turn on now?
If so your convergence chips are shot and need to be repalced. You can get a replacement kit and instructions from www.TvRepairKits.com.  If the set tubes still don't light up after yanking 1516 the problem is elsewhere. Most likely the HVG.
Posted on Jan 07, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Need Parts Number For Flyback In Philips W/S TV Model # 51PP9303H/17
If you are not sure how to find/repair/replace the HVG yourself goto www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Posted on Feb 13, 2009
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
I got sound no picture
Most common problem Have sound no Picture Is Flyback Transformer is Bad on LSB
May 15, 2010 | Philips 51PP9303H Rear Projection...
Philips 46PP9302 has no picture and is making a chirping sound within the case.
I had this exact same issue after I attempted to replace the convergence chips on my Philips 51PP9303H/17. It turns out my solder was not complete around all the pins, like I had missed a few spots. Once I corrected that and made sure each pin was completely soldered around the pin, my issue with the no picture and chirping sound went away. So if you were working on the TV's circuit board prior to this happening, I would say to double and triple check your soldering. If it just happened on its own, then it seems the solder cracked somewhere on the circuit board resulting in one of the components to loose its full connection and functionality. I hope this helps...
Jan 06, 2010 | Philips 46PP9302 46" Rear Projection...
Repair man said my philips tv model #51pp9303h/17 needs coupler.
Tries Shopjimmy.com,Partstore.som,or Ebay.com.These Websites have refurbish old and new tv parts.
Dec 28, 2009 | Televison & Video
Volume but no picture
19a7683.gif Ecollier2012
Rank:guru_s.gif Guru
Rating: 91%, 89 votes
e7c2b53.pngI have worked on dozens of the DPTVXXX models recently all with audio but no video. In every set the HVG was the problem.
If you are not sure how to find/repair/replace the HVG yourself goto http://www.TvRepairKits.com to get their how to guide that includes the part numbers, suppliers, instructions, etc.
Its an easy do-it-yourself fix.
Jan 28, 2009 | Philips 51PP9303H Rear Projection...
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
Convergence trouble philips mod 51pp9303h/17
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
Oct 16, 2008 | Philips 51PP9303H Rear Projection...
Mar 17, 2008 | Televison & Video
Phillips mo.51pp9303h/17
TV made a popping noise and now it wont turn on or anything??
Feb 25, 2008 | Philips 51PP9100D 51 in. Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
