Question about MAG Optics
Where can I buy 112moldel to piece mounts and rings for my 338 mag lapu single shot
2 Suggested Answers
  • 48 Answers
SOURCE: I broke a piece off of my tripod mount, can I buy
Call us at 800 735-4373 if you are in the USA. From your description of the problem the answer is no. We would have to know which tripod and exactly what broke.
Posted on Oct 21, 2011
Can maxi mags be shot out of single six ruger
Yes. Any 22 long rifle may be shot using the .22 LR cylinder. Any .22 Magnum can be shot using the .22 Magnum cylinder.
Mar 20, 2013 | Ruger SINGLE SIX 22-22MAG 5.5 BL FS
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
What's mag
A mag or magneto is a coil of wire that is "excited" by a permanent magnet thereby inducing a high voltage to fire the spark plug with. Most single cylinder lawnmowers use mag and point systems to fire the plug. Coil is hard mounted and the permanent magnet is part of the flywheel with the points mounted under the flywheel.
A coil is a two coils of wire, one is connected to ground on one end and the other end is connected to either a set of points or an electronic switch, either of which turns on and off the current through that coil. When the coil discharges its electrical potential, its magnetic field collapses, inducing a high voltage in the other coil which is used to fire the spark plug.
Sep 30, 2012 | Generac Rv Generator - 6,500 Watt - 6.5 Kw...
Remington Model 10 Serial Number 115981. What year was it probably manufactured?
It seems there are couple different models to Remington Model 10, there is a smooth bore, and a SS (Single Shot). They were both manufactured in 1962, and both were stopped manufactured in 1964.
Nov 07, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
Where Lapu-Lapu went after them against magelan
To find out where the Lapu-Lapu people went after they encountered the explorer Magellan, you need to do an Internet search. Just access: http://www.google.ca and type:
where Lapu-Lapu went after them against magelan
and do the search.
Jul 12, 2011 | Computers & Internet
Hi my name is rolita lanzo, now my pentax optio baterry is not working anmore, i need to buy baterry, can you please help me to fine pentax shop here in davao?
Unfortunately, I am not super familiar with your area, but i did a little research, and there is a Pentax office in Cebu. they may be able to help you out.
Mactan Export Processing Zone 1,
6015 Lapu-lapu City, Cebu, PHILIPPINES
tel: (63)-32-3400-505
On another note, it would seem that your camera take standard 1.5V AA batteries. You can purchase these at any electronics/ department store.
Mar 03, 2011 | Pentax Optio E60 Digital Camera
HAVE SKS NORINCO CONVERTED TO USE AK47 MAGAZINES. MAG FALLS OUT WHEN SHOT ONCE OR TWICE. HAVE TRY MANY DIFFRENT MAGS I HAVE. ALL ARE TIGHT WHEN INSERTED BUT FALL OUT WHEN RIFLE IS FIRED.
I had the same problem with them, they don't work that great, I had better luck with the sks mag that was converted for removal. The ak mags, I had to grind them just right or they wouldn't work, I can't even tell you what I did it was a while ago, but I got them to work.Something to do with the keeper and the catch in the front. Check it out.
Jul 16, 2010 | SKS Rifle High-profile See-thru Scope...
On my sks rifle when stalling clip have to hold bolt back to install clip
Are you talking about a full magazine? You have to get the bolt out of the way because it is too tight? Take out 1 round and see what happens. Does it do it to an empty mag? You are not talking about a stripper clip are you? You know they don't come with magazines, the 30 rnd mags you get that are detachable have been modified some how. And they don't go in easy. Not like an AK, Let me know.
Apr 20, 2010 | SKS Rifle High-profile See-thru Scope...
How do I remove the stock mag and put a 30 round mag in?
You have to remove the stock to get at the forward hinge of the std. 10 round mag.
Nov 13, 2009 | SKS Rifle High-profile See-thru Scope...
Disassemble a remington 11-87 super magnum
Go to the link below to get the manual. In the manual it will tell you how to disassemble the shotgun. It starts on page 14.
http://www.scribd.com/doc/12887293/Remington-1100-1187-Super-Mag-Auto-Shotguns
Good Luck
Nov 01, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Optics Logo
Top MAG Optics Experts
NOEL
NOEL
David Payne
David Payne
Are you a MAG Optic Expert? Answer questions, earn points and help others
