Question about Garden
I have a garden line 139 mover. When you pull the cord to start it kicks back
5 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: Generator hard to start. Kick back
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
Posted on May 20, 2009
  • 903 Answers
SOURCE: my toro sel propelled lawn mover is not starting
You probably have grass or other debris caught up on the drive shaft. Turn the mower over, and where the drive shaft (that the blade rides on) disappears into the mower, squirt some WD-40. Make sure to go around the circumference of the shaft.
Then turn the blade by hand (carefully -- you might want to wear thick gloves) and apply some more WD-40. The blade should become easier to turn, which will allow your pull cord to be pulled all the way out.
If the cord pulls farther than it did before but still not far enough, repeat the procedure and apply more WD-40 or oil.
Posted on Aug 28, 2010
rycgl
  • 1545 Answers
SOURCE: Have a 2-cycle MTD garden
You will have to disassemble the machine down to the starter/recoil unit. Once you're there, you can inspect/diagnose what caused the problem and either order some new parts or rewind the starter rope and hope it doesn't happen again (which it will because of how poorly engineered and cheaply made the units are).
Posted on Apr 23, 2011
leewesson
  • 63 Answers
SOURCE: when i pull the cord on my lawnmower it kicks back and pulls the cord out of my hand
sounds like the SHEAR pin is broken, replace shear pin, this can cause the timing on the motor to be off. it is designed to protect the motor from hitting a stump, a rock, etc.
Posted on Oct 01, 2012
I had to change body chassis on husqvarna 240 chain saw, put back together and started once, then died,now won't start and gas comes out muffler. What did I do wrong
The unit is definitely seriously flooded. Dry the unit out and try to restart. Do not pull the starter rope more than 3-4 times with unit on choke. Kick it back to fast idle to start. If it floods again, recheck your fuel lines to make sure they are correct.
Mar 30, 2017 | Husqvarna Garden
When starting saw motor kicks back and breaks pull cord
sounds like the flywheel key is partially sheared causing it to be out of time
Jan 22, 2017 | Garden
How do I fix a Craftsman gas-powered push lawn mover that won't start? Already tried a new spark plug, and there is gas in the tank. Engine doesn't even begin to turn over
You need to add more info. When you pull the cord does the engine spin? If not the engine is seized or there is something stuck in the blade or the blade brake is stuck on.
If it does spin the take the spark plug out, attach the wire to the plug, lay the plug on a metal part of the engine and pull the cord. You should see spark jump across the gap. If you have spark then you have no fuel getting into the engine.
Dec 14, 2011 | Garden
Repair of pull start to garden blower
To replace the pull cord line:
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
7. Remove the wedge and allow the spring to pull the rope back into the recoil.
8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
Sep 25, 2010 | Garden
No start push mover Briggs motor 6.75 horse 22" blade. Let neighbor borrow. Lol the blade is bent pretty good. The engine turns over. Upon pulling the cable the mower turns over then recoils the cable back...
you have a sheard flywheel key - if have spark it will be at wrong time
hence the kick back !!!!
replace key in flywheel check flywheel for crackks and check pto for bend if bent have it straightened - replace pto seal and blade
assemble and test
cheers paul
Aug 06, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Starter rope needs to be replaced on torro mower
yes you can fix it your self go to your local home center buy a replacement mover cord. remove the cover off the of the mover. remove the old cord and wind the new on on to the spindle. remembering to load through the top cover hole first.then place the cover back on. next put the pull handle on and give it a go.
Mar 25, 2010 | Toro Lawn Mower With Toro Power Tools
The starter rope on my torro lawn mower broke, is this somthing I can fix myself
Mar 25, 2010 | Garden
42in riding mover leaving a high spot between blades blades just sharpened
Recheck your blades and make SURE they are both squarely on the line-up stars and pulled down tight. If you got one off just a little you will get the condition you describe
Sep 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
May 19, 2009 | Electrical Supplies
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
