Question about The Computers & Internet
I have a bunker hill dvr i don't know the user name or the password can i factory reset it and how
  • Keith Pritchett Apr 15, 2017
    Im sorry the bunker hill is a H.264-8ch dvr
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
SOURCE: Aficio 1035 web interface user name and password
The Default factory passwords are not what you have listed. They are the following:
User name: administrator
Password: password (or possibly leave blank)
Give that a try.
However, the web interface isn't all that special on this older model anyway. All you need to program are the Ip address, and subnet mask, as there is no scan to email function, and the scanning can only be done via a software, that you won't have, and is getting difficult to find, because it is no longer supported, and just as complicated to configure should you find it ("Scanrouter V2 Lite" is the name ) as opposed to direct scan to folder. By the way this scanning software is NOT Vista compatible should you find it.
If you can't log into the web interface....on the machine, go to "user tools', "system settings", Interface settings", and set your IP address and subnet mask...that's it.
Please rate response :)
Posted on Mar 24, 2009
  • 8197 Answers
SOURCE: I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Posted on Nov 15, 2009
  • 36 Answers
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
Posted on Dec 13, 2009
  • 116 Answers
SOURCE: What's default password and user name for Actiontec GT704WG
Default username is admin.
Default password is password.
I hope this helps!
Posted on May 13, 2010
Testimonial: "Thanks for the right answer!"
Bunker Hill security 8-Channel Surveillance DVR item#61229 keeps rebooting itself. "system initializing"
Rotorway Bunker Hill never lasts and it's the cheapest one with the worst resolution you just don't want to operate and put your life on the line with this unit
Jan 18, 2016 | Home Security
Can I use a Swann wireless camera with my bunker hill dvr? If so, how would I get the camera to sync to the dvr?
If they speak on the same frequency, that is a start to make them work rogether. I dont know the bunker hill dvr so if it talks on the same frequency, you have a start. Most often people hook 6p to an NVR.
Jul 03, 2015 | SWANN Home Security
How to reset password on DVR 8024
Here is a link to the manual if you need it:
Recommend use the user name 'admin' and password 123456 to see if it still works. Do not see a factory reset discussion.
Apr 19, 2015 | Televison & Video
Bunker hill dvr security
Your problem lies in the hard drive. It no longer is booting the DVR. There is a partition on the drive that holds the operating system so it doesn't get overwritten when the drive fills up with video. You need to contact the manufacturer to get a new hard drive since the software to run the DVR is on the drive.
May 30, 2014 | Bunker Hill Security 4 Piece Solar Fence...
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Bunker hill h.264 dvr reset password
Giuseppe musso, did you figure it out? I'm having the same problem
Nov 07, 2012 | Home Security
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
