Question about LG Microwave Ovens
I have LG microwave 21 ltr.min and hour buttons are not working. What to do
Lg lmhm2017st stopped working.
a problem with the control card that controls the functioning of the microwave
Jan 22, 2014 | LG LMHM2017ST Microwave Oven
Start button of lg microwave is not working
my lg microwave start button is not starting what do i do?
Apr 27, 2013 | LG LMV1680ST Microwave Oven
I need I know how to set the clock on an lg microwave model ms1446sqp
The MS-1446SQP is the version of this microwave sold in Mexico. To set the clock, press the button labeled Parrar/Borrar (Stop/Clear on English microwaves) in case any cooking programs are running. Then press the button with the clock face (Reloj). Then press the touch pad labeled Inicio/Inicio Rapido (Start/Fast Start). Type in the 4 digits of the current time (24 hour format). Then press Inicio again. (Note: I have left off the accents.)
The manual for the LG MS-1446SQP is available here: http://www.lg.com/mx/soporte-producto/lg-MS-1446SQP . The directions for setting the clock are on page 12 (pictures of the control pad are included). This is the Spanish version of the manual and is a pdf. Thus you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 18, 2012 | Microwave Ovens
MC-767W-WS LG intellocook microwave oven showing E-10 message only. What does represent and what is to be done. Amitabha Pal
microwave oven MC767W LG has not working it stop automatically after few min. showing 10.1 error
Sep 14, 2010 | Microwave Ovens
I have an LG Intellowave microwave model MS1942G and would like to know how to reset the clock please.
Push button that says 'clock' then use the '10min' button to set hour, '1min' to set 10 minute intervals, then '10sec' button to set minutes. Click 'clock' button again to save. The trick is to make sure the the colon like dot separator on the clock is flashing when you try to make changes. Did my head in working this out... in the end I had to ask my wife...
Sep 11, 2010 | Microwave Ovens
Can't set the clock on a 1987 Quasar Superwave convection Microwave MQ8777BW
I had a similar problem--no manual--but found this way to set the clock:
1) Be sure colon is flashing (unplug and replug)
2) Press the 10 HOUR/MIN, 1 MIN, 10 SEC/MIN, and 1 SEC/MIN buttons until the correct time displays.
3) Press the CLOCK button.
Hope this helps.
Mar 24, 2010 | Microwave Ovens
I need an instruction manual
press both Hour and Min buttons simultaneously for two seconds. You will hear a beep and the timer will reset. Don't press any other buttons for twenty seconds. The display will now change from the time to the clock. Press the hour botton. The hour digit will blink. Use the Min button to set the hour. Once you have the right hour, press the Hour button again, and the minute digits will blink. Press the Min button to set the minutes. Once you have the correct time, press the hour button one last time and your time is now set.
Sep 16, 2009 | Microwave Ovens
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
