Question about The Office Equipment & Supplies
Power still blinking while error is still there nos_loader_app the cartridge is not moving, what will I do?
Cartridges won't move
turn off open cartridge unit and try to pull the whole print head. some units you can move only when off. if too hard then its locked. make sure cartridges are set correctly in place if it has a lid make sure its closed( for printer head not printer)
Mar 25, 2014 | Canon PIXMA Office Equipment & Supplies
Hp envy 4500- error code ox83c0000a nos loader app
I have an HP Envy 4500. Rather new and it shows: Error Code 0X83C0000A NOS_LOADER_APP What do I do to fix?
Aug 28, 2013 | Office Equipment & Supplies
What's C 5 E blinking in the printer screen?
The EC5 error code indicates that there is a short in one of your print cartridges. Please follow the steps below to identify and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance.
Oct 10, 2011 | Lexmark X2600 InkJet Printer
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
When i turn on my Deskjet 1125C printer, the cartridge cannot go to the center, the carriage moves from side then it stops moving, then the resume and power led power blinking. i also cleaned the mechanism...
According to your problem first check and make sure that the ink cartridge of the printer are not blank and not get dry also. Check the belt by which the cartridge moved, if it is getting loose. Tighten the screw of the cartridge moving roller. It will help you.
May 13, 2011 | HP DeskJet 1125c InkJet Printer
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
I have a verifone Nurit 8020 which displays "Tampered Device". The company says I need a replacement. Is there any way to fix this?
do you have available Nurit 8020 terminals currently?are you purchase any tool for this? if no i have tamper recovery tool for this device.
Aug 24, 2010 | VeriFone (M19755014US1) Magnetic Card...
How do you reset lost password on Nurit 8020
Power down the unit and with your right hand hold down the 1 5 9 and enter keys down. While those keys are pressed down with your left hand turn on unit it should take you to that nos loader menu. Once in the nos loader menu choose back to NOS password is 1947. Once in the NOS menu choose number 6 Service Menu
then 1 Hardware test
then 15 RAM test this will state this terminal will self destruct continue. Hit enter and it will create a new RAM disk once you see the date & time if correct hit ESCAPE if not correct D & T hit enter then put the correct info in Military time MM/DD/YY format. Hit enter and it will take you back to your main screen with the original password of MMDDYYYY that is your password.
Nov 21, 2009 | VeriFone (M19755014US1) Magnetic Card...
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
27 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
