Question about The Office Equipment & Supplies
HOW DO YOU MAKE THE PICTURE LIGHTER AND WE'RE IS THE DRIVER SETUP WINDOW ON THE PRINTER?
Only get zig zag lines in viewing window no picture
1. try to setup a different setting in setup menu where are you can setup the NTSC or PAL sistem2. change the driver
I think the driver change will help.
Feb 01, 2011 | KWorld PC to TV (0872880887527) Video...
Printer will not respond to laptop
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side. Please refer the below picture to view the port on the printer.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:\WINDOWS\I386 folder.
  • Remove and reconnect the printer.
Jan 27, 2011 | HP PSC 1350 All-In-One Thermal Printer
Need to know how to setup print without cd
Installing a printer without CD is done in the same way as with the CD but you will have to browse the driver from a location on your PC. Steps:
  1. Download, save and extract (if applied) the desired print driver from the maker of your printer.
  2. Go to Printer setup window (in case of Winsdows operating systems, you need to check devices and printer)
  3. Add a printer
  4. Select the printer port, (insert IP address if printer is networked or point to the correct port in case you use other connection type)
  5. Click next and it will request for the printer model and driver. Now select, "FromDisk" and browse to the folder you extracted the files to. Step 1
  6. Follow the normal instalation wizard.
Sep 07, 2010 | Office Equipment & Supplies
How to download installer without the cd?
you can install printer with window basic driver but this printer is new so window do not have the default drier for this printer you need to install driver from internet and then install your printer, follow this step to install printer and download drivers,
1. click this link to download driver for your HP F4100 printer FROM HERE.
2 select your printer model.
3. select your operating system.
4. then download the HP deskjet full feature software and drivers.
5 when download complete run the setup file to install driver for your printer.
6 do not plug the usb cable to your computer until setup prompt you.
7 follow the onscreen instruction which is coming on setup page.
8 and your printer is install and ready to use.
Thank you for using fixya
Regards
Manish
Jun 09, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
Failed Wireless Setup/could not create new port
Check this link for wireless setup:
http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Image and text printed multiple times and are overlapping
Is the R1800 the only printer that you have on ythis mac?
If it is make sure it is directly connected to your mac via a USB or Firewire cable.
Trash epson folder from Mac HD-Library- Printers
Delete Epson printer utility from Mac HD- Application folder( if you have both delete both icon.
Under prnter setup utility delete the r1800 printer
Go to finder click on file the find, type com.apple.print, if it find anything drag it all on the trash, it will not disappear from the window ( the prefs and . cache files)
download the latest driver for your r1800 from epson website
epson12113.dmg - 10.3MB - posted on 12/20/
then reinstall it, after reinstalling try to readd th printer and make sure under print using it will say Epson SPR1800 series. If you see guten print/ that is a third party driver. dont use the gutenprint. then try to print, update me for the outcome
Apr 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Colr red
Open the Printer Driver Setup Window and look at colour preference then select manual.
You will then a picture of a boy and adjustment controls for the colour set them to reduce the red and how you would like your photos to appear.
Mar 24, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Printer Setup
Dear Summer_girl,
Click on the link below & select your options, you can download the driver for free!
http://software.canon-europe.com/
Cheerup and Be Happy always
Mar 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Driver Installation
Solution: Uninstall / reinstall the printer driver (Windows) PIXMA Printers
Uninstall and Reinstall the Printer Driver (Windows) Follow the steps below to uninstall the printer driver:
  1. Select 'Programs' or 'All Programs' from the Start menu.
  2. Select the Canon printer driver you want to uninstall, and then select 'Uninstall' from the menu that appears.
    Note: Click here if your printer does not appear in the Windows 2000, Windows XP or Windows Vista Programs menu.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and then click 'OK'.
    Note: If you use Add or Remove Programs to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in step 2.
In Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
  1. Make sure your printer is connected and turned OFF (or the power cord is unplugged).
  2. Turn on your computer and log on as Administrator.
  3. Open the Printers window.
    For Windows Vista
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    Right-click the Canon printer icon for your model printer and click Delete.
  4. Click 'Yes' to proceed with the deleting process.
  5. Click 'OK' to acknowledge you have deleted your default printer.
  6. Click 'File' from the Printers window then click 'Server Properties'.
    Note: For Windows Vista, click your right mouse button on any empty space within the window, and then select 'Server Properties' from the menu that appears.
  7. Click the 'Drivers' tab. Select your Canon printer from the list and click 'Remove'.
  8. Click 'Yes' to proceed with the deleting process.
Follow the steps below to reinstall the printer driver:
  1. Turn off the printer.
  2. Connect the printer cable to the printer and the computer.
  3. Turn on the computer, and start Windows.
  4. Insert the Canon Software Setup and User's Guide CD-ROM into the CD-ROM drive. Setup Starts automatically.
    Note: If Setup does not start automatically, click 'Start' and then 'Run' from the taskbar. In the 'Open' box of Run window, type x:\msetup.exe (where x: is your CD-ROM drive letter). Then click 'OK'.
  5. When the Master Setup screen is displayed, click the 'Custom Install' button.
  6. Uncheck (click on the check marks) all items listed except for 'Printer Driver', and then click 'Next'.
  7. When the License Agreement appears, click the 'Yes' button after reading the agreement, and then click 'Next'.
  8. File copying begins. After all files are copied, the Printer Port dialog box is displayed. When the dialog box is displayed, turn on the printer.
    Note: If the port is not detected at this time, disconnect the cable from the printer and reconnect it.
  9. Click 'OK' to end the printer driver installation.
Note: If you previously used a Canon printer that was connected with a USB cable, a message reporting that the USB driver will be updated may be displayed. Click the OK button to update the USB driver and restart Windows.
Dec 30, 2007 | Canon Pixma iP6000D InkJet Photo Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
