Question about The Office Equipment & Supplies
How can I just reset. the cartridge cannot be out still error
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
What mean error code pixma printer mp 145 ( E 8) ?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code Message for Printer Canon MP145 and Canon MP160:
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Jan 02, 2011 | Office Equipment & Supplies
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error – USB
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer won't recognise cartridges UO51
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 22, 2009 | Canon Pixma MP450 All-In-One InkJet...
On the screen show 5e
Procedure to reset Printer canon MP145, MP150 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How can i reset the ink cartridges
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 19, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error Message 22, but can't reset it.
First make sure there isn't any thing keeping the carriage from moving freely, the reset as follows:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Dec 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
27 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
