Unitary heat pump Model No. XP150coon2AA: tonnage? Serial n# N1K1296819: age?
  • Heating & Co... Master
  • 1,448 Answers
Looks like a commercial unit. 12.5 tons. Likely a 1996
Posted on Apr 15, 2017
WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
May 09, 2012 | Heating & Cooling
Have serial # B60700097 older heat pump trying to degtermine year and size?
Hi, according to this serial # it is a 1997 heat pump. I would need to know the model to tell you the tonnage on this unit.
Sincerely,
Shastalaker7
A/C, Contractor
Jul 25, 2011 | Amana Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
May 08, 2009 | Heating & Cooling
Age and tonage of carrier 38CKC036350 S/N 2005E40526
its a 3 ton unit manufactured in 2005
the 36 in the model number indicates tonnage 12,000 btu's to a ton times 3 equals 36
the 2005 in the serial indicates year made not sure what month but if i had to guess i'd say May of '05
Thanks Peyton
Mar 13, 2009 | Carrier 38CKC042 Air Conditioner
Someone has an Intertherm outside 3.5 ton a/c unit for sale but doesn't know anything about it Model 5SQD-042KA Serial S5A070500546 Can you tell me how many SEER, heat pump or not,...
There should be a square sticker or metal plate that tells you the model # the #'s that comes close to the multiplecation of 12 =to tonnage,example ( asbv036g-1 the 36 = 3 tons 12x3=36 (gdhe420-1 = ==3-1/2 tons cooling 12x3 plus 6-1/2 ton = 3-1/2 tons the serial # tells the year it was made.....080808 , the first 4-#'s tells you the month--- for 4 #'s this is aug.- year 08 !
Sep 05, 2008 | Intertherm Heating & Cooling
CAN' READ PLATE ON A/C - CAN'T TELL TONNAGE
that comp is a 25k btu depending on the age of the unit it is a 2 ton or 2 1/2
Aug 10, 2008 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
