I walk out on a span of a bridge made by man looking down at the water so cold god sent a angle
    Master:
  • 410 Answers
God Sent an Angel
I was troubled in my mind and had reached my darkest time
When my life and my spirit was low.
I walked out on a span of the bridge made by man
And looked down at the water so cold.
I stood shivering there on the edge of despair,
Knowing well I was going to fall
With the end drawing near I had no mortal fear
For I had never known him at all.
Chorus:
But God sent an angel that only my eyes could see.
He was dressed all in white and surrounded by light.
Oh, thank God for the love shown to me.
For the rest of my days, God will show me the way
Since His messenger entered my life.
I'm a part of His plan for salvation to man,
As I walk through this circle of life.
Never more will I doubt what my life's all about
And no more will I suffer despair.
I've got proof He's alive, for He let me survive
And I know He's made a home for me there.
God Sent An Angel
Recorded by Doyle Lawson
Written by Doyle Lawson, Leroy Drumm, Pete Goble
C C7
F C
C7
D7 G7
C C7
F C
F C
G7 C
For I had never known Him at all
G7 C C7 F G7 C
But God sent an an-gel that only my eyes could see
F C
G7 C
Oh thank God for the love shown to me
C7
For the rest of my days God will show me the way
F C
C7
I’m a part of His plan for salvation of man
D7 G7
As I walk in his circle of life
C C7
F C
F C
I've got proof He's alive for He let me survive
G7 C
repeat #2 Cause God sent...
F C
G7 C F C
Oh thank God for the love shown to m--e
https://youtu.be/zrllaDrg0EE
Posted on Apr 15, 2017
Tip
How to reset/recalibrate your treadmill after replacing drive or incline motor,...
Make sure you recalibrate your treadmill after installing ANY controller, motor or console. You can NOT over calibrate your treadmill. You want to make sure you adjust your pedometer for the correct operating speed and incline adjustment. First plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. The adjustment is made with a phillips screwdriver, and the adjustment point is on the motor controller. It is a little square metal box with a yellow plastic adjustment screw inside. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode. Double check that the treadmill is operating at the correct speed and incline motor works correctly, by running maximum settings. Once you are done, be sure your treadmill is properly protected from surges from power spikes that can destroy the work you just performed.
Hope this helped.
on Dec 08, 2011 | Nordic Track Exercise & Fitness
4 men approach a rickety bridge at night. They are of varying ages, and as such take different amounts of time to cross the bridge. Since they just have 1 lantern, and only two men can cross at one time...
perhaps the man that can cross longer minute is old.. so u have to carry that person.. so then cross by two's each one of them carry a person that walk slow..and you cant leave one or two behind co'z there's only one lantern
Jan 26, 2012 | Computers & Internet
On switching on the display is okay but every 3 or 4 seconds superimposed on top (hence I think the screen is not damaged) there are vertical lines of different colours with flickering. These span about 2...
This is a bad solder connection on one of the matrix controller chips on the LCD screen. You'll need to solder it back down.
Either have a professional (the kind that looks at the issue and says "yep, that can be fixed") or if you insist on doing it yourself, make sure you have liquid solder flux to avoid bridging, and fine desoldering braid in case something bridges anyway, and a magnifying glass or low power microscope to see if you bridged any connections before powering the screen back up.
Hope that helps!
Feb 25, 2011 | Computers & Internet
Stops mid cycle
Sounds like a cold water problem. Try running washer set for cold water only. See if it stays running. Most rinses are cold water. If you have low water pressure it can stop due to protection circuit that allows washer to fill for only so many minutes. If it isn't full at end of time span, it may shut down. Try checking inlet valve screens for restriction. Turn off water and remove hoses from back and look into place where you removed hoses. You should see a screen in each one. Scrape out build up with a small screwdriver. Flush out with water.
DO-NOT remove screens to clean. If any debris gets into valve it can cause valve to remain open, flooding house.
Apr 01, 2010 | Zanussi ZWF1640 Front Load Washer
Can you help me get past the part in god of war 2 where your supposed to get wings under a bridge
A save point will be to the left and a --GREEN CHEST-- and --BLUE CHEST-- will
be off to the right upon exiting the cave. Walk over to the bridge then jump
to the next section and walk to the end of the bridge for a cutscene.
This battle will start with an Action Sequence.
This first part of the battle will decide which character will be on top of
the other as they both plummet into the chasm. Fail to press the proper
directions and Icarus will automatically win
Once the two have started falling, tap [], /\, or O to attack Icarus while
falling into the chasm below.
Jan 13, 2010 | Sony God of War 2
Kenmore ice maker no water fill
Now if you checked both solenoids ant you know the valve opens to send water to ice tray then we need to consider several other factors. Thermostat heating element under the ice tray, limit switch inside gearbox, blown fuse in the wiring harness between ice maker and plug receptacle. Now I am willing to walk you through this and we may find the problem right off. I have a diagram of the ice maker and I will send you all the repair parts or manuals you need. My e-mail is
seabreezehvac@yahoo.com email me and I will send your manuals PDF format. Or visit my site’s we offer free help and any answers you may need, Here is my sites. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Sep 22, 2009 | Refrigerators
Shower cold water won't shut off
You can repair it from the front. Worst care replacing the whole stem assemble. Take it out from the front,  see what is wrong (Washer  fell off?, Stripped stem?) Take the old part to the plumbing supply that sells that brand and match it up.
Mar 14, 2009 | Plumbing
Im really stuck on enchanted, the bit where you have to walk on water. ive done the singing, but nothing happens and i dont know what water im suppposed to walk on or whether the bridge is supposed to come...
go to the tunnel that woz once blocked off near where u can save, go throu it and then go right climb down the wall, then sing on the stage, come straight off it in 2 the water, walk straight ahead' then sing again and go right u'll get 2 the animals and that should b it, hope i have help u..
Dec 27, 2008 | Nintendo DS Lite Console
Walk on water - enchanted
When you get taken back to the cliffs go all thru back to the start of the cliffs. Walk through the tunnel and get a new animal then back out the tunnel, sing, back in the tunnel and walk on water to the rainbow bridge.
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
