How to adjust sound quality on m60 tv - Televison & Video
Sound driver
If the sound driver you're after is for the XP version then here it is, BUT if later version such as Vista, 7 or 8 then I can't help you. http://www.dell.com/support/troubleshooting/us/en/19/Product/precision-m60
May 03, 2013 | Dell Precision M60 Notebook
Could tv star t1020 box cause reduced vertical picture
The box may be causing this, many now have adjustments in their menu for centering and height and even width of the image.
It of course can be a problem in the set but that would show even with the box removed.
Dec 12, 2012 | Sharp 19G-M60 TV
1996 sharp tv model # 25H-M60 co-ax pulled out from the circurt board. I removed the back of the tv,and can see the female end is snap off the case that houses the board. Can i solder that back to the...
That is what the service provider would do if you took the television in to be repaired. The service provider would attempt to solder the rf connector back to the television or solder a new rf connector to the television.
Mar 29, 2011 | Sharp 19H-M60 TV
I need to by a new reomte for my Sharp TV 19H-M60 My old one is beyond repair Please let me know how to obtain one Thank YOu Joann
Hello
Just buy one "Comcast Ondemand Custom DVR 3 device Universal Remote control". Sharp Tv is listed in its manual. Codes are 10093, 10165, 10386, 11602. Proceedings for setup will be there with its manual. OK.
Jan 07, 2011 | Sharp 19H-M60 TV
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Sharp 25H-M60 landlord broke off the cable connector!
depends i have replaced these alot the part is cheap but you have to be careful when repairing this problem you can really mess the tuner up then it cost more starts any where from 40.00 to 80.00 dollars the parts cost pennys okay it's all labor have a good day tv man
May 14, 2009 | Sharp 25H-M60 TV
No sound.
If you have a cable box reset it by unplugging it from power for about 5 seconds. Hope that works.
Jun 12, 2008 | Sharp 13H-M60 TV
Universal Remote control code on Sharp 13H-M60
Your remote should have come with a sheet of paper with all the codes on it for different TV's, VCR's, , etc.
Sep 03, 2007 | Sharp 13H-M60 TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
