Question about Fellowes Office Equipment & Supplies
My fellowes shredder has a problem. When I try to shred 1 sheet of paper the orange light comes on and sometimes it will start and stop half way.
    Top Expert:
  • Fellowes Master
  • 12,962 Answers
Mechanism that detects paper in path needs repair.
Posted on Apr 15, 2017
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
Why paper won't feed when shredder turns?
This may seem to simple but.......sometimes when you put too much oil into the blades through the top portion, the paper get drenched with oil and will not feed in. Plz try a few sheets or a thicker paper to push through. It may just be that simple. Good luck.
Plz N' Thnx, Bogie
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Fellowes c-220c always full
there is usually a flap that leans into the paper tray and when it gets full the shreds push on this flap and activate a switch...
look for the flap and see if it bent or came off it's hinges.
Apr 14, 2010 | Fellowes DM15C Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
59 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
