Question about Spirit Exercise & Fitness
What's th input voltage for a spirit esprit el255 x trainer. We have been given a machine. The original power pack has been lost. 2 buy a replacement we need to know th input voltage into th machine.
pravinbhavsa
  • 348 Answers
SOURCE: need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Posted on Nov 20, 2008
SOURCE: need to replace lost power cord fpr back pack bantam 181100
the factory power transformer is 5V 1 A model TRX-022A input is AC100-240V 50/60 Hz 0.15A output DC5V 1A
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: 7 port usb hub
5V DC 3.7A  center + Adapter : )      Jay........
Posted on May 29, 2009
  • 20 Answers
SOURCE: What voltage and amperage the western digital
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Posted on Mar 01, 2010
  • 5 Answers
SOURCE: input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
Posted on Apr 07, 2010
Can anyone provide me with a manual for the Torpedo Elliptical Cross Trainer
Manual for Torpedo Elliptical Cross Trainer - Fixya
www.fixya.com/.../t3961893-manual_torpedo_elliptical_cross_trainer
Jan 24, 2010 - Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to ... Dear Sir: Please ...
Nov 23, 2015 | Exercise & Fitness
000 wd5000c035
Yes, this model is certainly compatible with Windows 7.
If you've lost the AC adapter and need to replace it, the most important things to look at are:
1) the size of the plug
2) the input voltage of the drive
3) the minimum current in Amperes (A) or milliAmperes (mA) required
For units manufactured after June 1st 2008, these are the requirements:
12 Volts
1.5 Amps
18 Watts
Western Digital recommends only using original WD power adapters.
See here for more information: https://wdc.custhelp.com/app/answers/detail/a_id/1378/related/1/session/L2F2LzEvdGltZS8xMzg3MTQwNTQxL3NpZC9aNG1NbVZIbA%3D%3D
Tip: sometimes you can find a cheap and original power adapter on eBay or Craigslist or Kijiji.
Dec 13, 2013 | Western Digital Elements powered by WD 320...
Spirit-esprit-el1-elliptical-trainer no display
1) replace the batteries by new one with alkalines type and using the same polarities DO NOT use another mark example sony vs everyready. Clean the contacts batteries.
2) Adjust the REED swtich, clean it, tight the connector very well, see the diagram and proceed.
God bless you
Nov 12, 2012 | NordicTrack Treadmill
Why does the display say L5
this a problem in 2 ways:
1) test the input voltage motor, if there are the motor need repair.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram atached.
Sep 07, 2012 | Landice L8 LTD Cardio Trainer Treadmill
We have a Free Motion Tt30 Incline Trainer making a loud noise that sounds like a bearing going bad, then the noise stops. Do you have any repair suggestions?
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Sep 06, 2012 | FreeMotion Tt30 Incline Trainer
Is buying a refurbished elliptical trainer a good deal?
Most elliptical machines that have been refurbished are around 2 years old. Essentially, the machine is cleaned up and broken parts are replaced. Refurbished machines can sometimes look used, but if that doesn't bother you than it may be worth buying one if the price is right.
Aug 02, 2012 | Exercise & Fitness
The treadmill will turn off while in the middle of a run. After a couple of min. it will turn back on.
hi, please check when machine turn off display is gone or not ,IF display is gone pls check power point, IF display is not gone check the current rating with load ,
Dec 09, 2010 | Spirit Esprit ET-8 Foldable Treadmill
Need to replace lost power cord fpr back pack bantam 181100
Mar 09, 2008 | Micro Solutions Backpack Bantam Triple...
Playing xbox (NOT 360, the old one)
go to your nearest gamestop or ebgames, mine had 2 of them. :)
Oct 06, 2007 | Pelican PL-2043 XBOX SPIRIT WIRELESS...
Exercise & Fitness Logo
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
