Question about Refrigerators
I have a 2 door waeco 12v 220l(I think) and it won't turn on. I've changed around every fuse I can find but to no avail. Not even the fridge light comes on?
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
SOURCE: waeco cf 40 portable refrigerator runs continuely
This is not an uncommon problem and you're probably experiencing a voltage drop between the battery
Posted on Aug 30, 2010
  • 137 Answers
SOURCE: Our Sony Bravia Tv was
If theres absolutely no power and no lights on, it sounds like the fuse inside the t.v.. It is pretty easy to change. You have to take out the screws on the back of the t.v. and take the back cover off. Look for a 3/4" glass tube fuse and see if the tiny wire in it is broken. Pop it out and bring it to radio shack and get a new one. Put that one in and try it, Make sure the t.v. has been unplugged for at least 2 hours before opening it so the capacitors have time to drain. They will hold power and could shock you if your not careful. Also, dont use anything metal to take the fuse out.
Posted on May 15, 2011
  • 22306 Answers
SOURCE: I've had my 320 CLK
ignition switch contact or starter motor given up the ghost ,try a jump start and see if that works ,do the lights go dim when you try to start it??if so then its a flat battery or a old battery thats just died on you.These vehicles do have a big ignition lock in the dash and these just dont go wrong like a VW but its possible?
Posted on Aug 17, 2011
  • 43501 Answers
SOURCE: Kenmore 70 Series Dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Posted on Sep 19, 2011
Hi I have a Waeco CFX50, only had it for 2 months. 240v no problem, was running on 12v off camper and it stopped after6 hours Using my multimeter I am measuring 13.2 v Any ideas?
  • is that 13 volts with fridge on
  • check the ampage reading on the battery also
  • would think its a warranty question
  • no idea what the 3 stage battery protection means
  • sellers claim
  • Operates on 12/24 volts DC or 240 volts AC
  • 3 stage battery protection
  • 3 year manufacturers warranty
Nov 12, 2016 | Refrigerators
The light globe in my 140 litre 2door waeco fridge only lasts about 5 to 10 days before it blows again. The globes are 12 v 5 watt genuine waeco globes. How do I fix this?
It could be that the fridge's voltage regulator is putting out a higher voltage, but likely it is something else. Check that nothing is blocking the bulb and causing it to overheat internally limiting its operating life.
Feb 01, 2015 | Miscellaneous
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
